All Forum Posts
More magneto mire
Managed finally to get all the parts back into the mag only to find that the driving-end cover will not go on properly. It stops with about a 1/16" gap between the cover and the body. It is prevented from moving any closer by the locking nut.
Manx Norton
I have a recently aquired 1956 manx but can find little in the way of a comprehensive workshop manual, any ideas where I can find a good manual
s+b filter
I have been running my mk3 with bellmouths fitted(odd ones so they fit),just fitted a s+b one piece and it run crap,will I need to re jet ? if so any tips on size etc.
ta Pete
Re: Norton 99 1959
Would someone be kind enough to tell me the correct thread size for the 5/16 front fork studs (4) which retain the front mudguard support bridge. They go into the ally lower fork leg and I guess they are either BSF or BSW.
Bashed battery platform
Attached is a picture of the battery platform that I've just removed from my bike. As can be seen, someone has taken a blunt instrument to the front end in such a way as to lower the height relative to the front mounting ears.
Tents
I'm in the process of buying a new tent for rallying and general camping. I'm looking at a Coleman Coastline 3 Plus. Has anyone any experience of this tent. Alternatives seem to be the Lichfield Arisaig 3 person and the Vango Beta 350 XL.
Indian yokes
A friend has lost the yokes for his 1926 16H. Has anyone got a set.
I see a set on E XXX made in India. Has anyone used such an item from India, any advice on same would be great.
Thanks Robert
Gearbox gaskets
Whilst rebuilding my gearbox I noticed that there is only a 1/4" hole between the outer case and the inner chamber to allow oil to level between the two.
Mike.....new member
Please can anyone help with a problem I am having regarding my Norton 961 Commando. The fuel tank fixings have been replaced once already and the tank seems to be still a bit loose fitting especially on the right side.
