Horn issues
I am a Commando owner since one week now and need to get it past the road test. Just discovered the horn is not working...
Brand new Manx Norton 350cc Short Stroke Cylinder head with provisions for Twin Spark
My Speedo and tacho are away being reconditioned. In the meantime I’m going to remove the instrument housings, which are unpainted alloy on my ‘72 Commando, and give them a polish.
My Atlas clutch slips a bit when its cold but after 5 minutes or so of riding it stops slipping.
Has anyone measured the force needed to pull the handlebar clutch lever to open the clutch?
If someone has what force was needed.
I hate to bring this up again but here goes anyway.
A Dominator I am rebuilding came with rear shocks shown in the picture. At 70mm diameter they are too wide and foul the mudguard.
Dimensions are 11" x 2-3/4" shroud diameter.
Does anyone know what they come from?
Hello i want to ask if is useable this rim for my norton international prewar road model?
Tomas Tesar
Hi, I need to replace the Contact breaker oil seal and I see on the Andover site they list a special tool to aid fitment. Can this be fitted without the need for the tool and if so how.
Thanks in advance.
Keith
For some reason i cant view the additions . Is it me or a computer glitch ?.
My 1957 "dynamo" Dommi 99 has a speedo drive box with no identifying numbers. It's knackered.
I have a '57 600cc single engine in a '48 ES2. I've currently got the engine apart to sort a crankshaft end float problem.
I've assembled the crankshaft into the cases on my 850 engine - fresh grind, new mains, new shells, new new AN conrods, N.O.S Hepolite pistons(std), new liners fitted. I noticed that the T/S piston wasn't level
Something i have not seen before ,wear in the steel ? bush.
Hello,I am seriously thinking of signing up for the Beamish trophy trial this year, just wondering if anyone has a pre1980 enduro/trail bike at the back of their garage that would fit the bill and would consider selling, I don't want to spend a lo
The threads in my 650 swinging arm are stripped . I think they are 1/4 cycle . I ordered new adjusters and happily they have turned up larger !. Perhaps my luck is changing . When did they increase the thread size and what is it ?.
Early clutch so 1st plain plate is attached to clutch basket with 2 roll pins that have sheared.
Is there a standard size or do I just measure the diameter and order nearest mm size from e-bay?
I am about to start building my Mk3 front wheel. I have two wheel types here.
Please help!
My engine (2012) is beyond repair.
Does anybody have one engine in good condition / new for sale? Or a tip?
Please a private message to gabvyskocil@gmail.com
Gabriel
Hi does anyone know the answer to this?
Hello,
I have a Manx Norton G9-57 Laydown Gearbox for sale,
This has recently been serviced and had new parts where needed including a new 2nd gear & 3rd gear. Invoice available for buyer.
Hi, Has anyone purchased Commando MK3 down pipes (exhausts) from Armour Motor Products Ltd in Bournemouth? If so, would you kindly let me know if the pipes fitted correctly and give their opinion of the quality of the pipes.
Hello.
I’m in the strip down and assessment phase and have so far discovered that my bike is an early 650ss engine in a 1966 88 Chassis with a 99 barrel. The bike was assembled by someone with zero mechanical aptitude.
My ES2 lost it's original mudguard 50 years ago during a mild attack of customising. The old mudguard never made it to Sweden, where I live now.
Hi, Does anyone have any factory dimensions for positioning the 'Norton' and '750 Commando' decals on tank and side panels...or is it just a case of gauging the position from photos?
Cheers, Len
Can anyone provide the RAL blue colour for 1972 JPN race bike - or the Donington 961 Mick Grant tribute bike. Mr Google has drawn a blank!
Thanks, Mike
Raised this thread to remind folks that the Parts Commissioning system is still live and always ready to accept the requests raised through the form at the head of this forum.
