All Forum Posts
62 jubilee
Any suggestions who to contact re fastening nut/bolt/studs? My bike was bought 'complete' but is far from & I'm struggling to find odd bits.
TIA Andy
Settling an argument
Can anyone tell me if this was a factory colour scheme? I have recently re-introduced it to the road after an extensive rebuild. I bought it in a partially assembled state with an option of tanks, Roadster or Interstate.
Hydraulic front brake
Over the years I have seen a few Nortons with a hydraulic  front brake conversion, utilising parts from some car or van, does anybody know what the donor vehicle was?, I know there are probably dozens that would do, but scrapyards don't let you wa
ES2 torque settings ?
I'm getting ready to assemble my 1962 ES2 engine after a complete overhaul. I have not been able to find info on torque settings. Specifically the 3 sizes of case studs (5/16 3/8 7/16), head bolts and rocker box.
Fuel tank painting.
The tank and side panels on my 1978 Mk111 are being re painted to a near enough match of the original colour, silver. I would also like the red & black pin stripping included prior to the tank & panels are laquered.
Jubilee speedo
Anyone any experience with speedo drives? is the number specific to the bike or generic? Mine's not working (think the worm drive's gone ) number's BG5330/247 2:1  - can find others that look similar but have different numbers
Unknown Crankshaft
The 850 engine I'm rebuilding came from a machine where the engine was bolted solid into the frame. How would I be able to tell whether it has had it's balance factor altered?
Atlas or Not-las?
in my last post I was awaiting collection of my new project - my first Norton - a 650ss in an Atlas frame. I was pretty certain the engine is one of the first 650ss from Sept 1962 as the serial number and stamping says so.
Laydown gearbox
Canada calling. The kick starter shaft on my lay down Model 7 gearbox has two grooves which would appear to be for o ring seals. Checking the gearbox diagramme no seals are shown. Should there be a seal? Thanks for your help.
