All Forum Posts
Dominator Battery
Hi apologies if this has been covered in this forum already. I recently bought a Dominator and it has to be kept on charge which is ok but even so it's still tricky to start.
1947 16h Carb
Hi the correct carb for my 16h is a 276AT/1BE however this is completely worn out and needs replacing,would any stub fitting 276 with the correct jets etc work,I'm also at a complete loss as to what the AT/1BE part means.Any help would be apprecia
cotton reel hub
hello,
could anyone tell me if the nuts that hold the rear brake drum onto the cotton reel hub are normal thread. they are very tight . can seem to budge them. ive tried shouting at them, but that didnt work.
barry
Front Brake Binding
I took my ‘72 Roadster out yesterday for the first time this year.  After 5 miles I noticed that the front brake was binding and I had zero play on the brake lever (it had gradually been reducing).
Frames
Hi, can anyone tell me if the 1972 Interpol frame is the same as the Interstate frame? Due to arthritis, I'm planning on converting my 750 JPN replica to an interstate, with an easier riding position.
Front Brake Switch
Hi everyone, is there a switch for front brake lever? If there is something available please let me know where to buy one? I have looked on Amazon but didn't find one.
Many thanks Roger
SS Camshaft ?
My Dommi 88 is fitted with an SS Camshaft ( marked T2219@3 ) it seems. Does this require Pushrods and Valve springs as used on the 650 SS and Atlas models to be fitted ? I came accross this advice in the Haynes Manual (chapter 1 -22 ) .
rear brake plate
I bought a rear brake plate for my Norton 650ss - advertised as Dommie plate but the brake shoe pivots have wire circlips instead of retaining plate/tab washer and bolts.
I assume it's an earlier plate from ES2 or very early twin.
1938 16h Norton.
Hi to all. Can anyone tell me the length of the clutch rod that goes in a dolls head gearbox. As I have ordered and received one but it seem to be two long. Any help in this matter would be.
bob
Hogslayer
NOCcer Fans of 1/4 mile racing will be delighted to hear that Hogslayer, the twin-engined Norton raced so successfully by Tom "TC" Christenson back in the 70's will again be pounding the asphalt at Santa Pod this summer.
Clutch Question
1948 ES2... Just replaced the cage and rollers in my clutch as the old one was so worn the rollers were falling out.
When I tighten the backing plate nuts the rollers lock up. I have double checked the components and all seems correct.
