All Forum Posts
domi gearbox rebuild
im finishing up the gearbox rebuild for my 58 domi and ive noticed the washer in the clutch cable release arm seems over sized for the bolt and leaves alot of play is the correct ? or do i need to replace it
Clutch Compatibility
Hi been reading some old books, Franks and Garratt, much more information ln them,  So the Norton twins run from  1948, the clutch being altered slightly, can an earlier pre-war clutch be used in a 99, or a Pre-1956 unit, or is this a no-no!
Rear stand bolt size
Can anyone tell me the size and thread of the rear stand nut for a rigid? Ten quid each is a bit minty for my leaking pockets! Cant find them on spares shop on here unless they share a common use for something else or another model??
cylinder head
Hello
I want to remove my cylinder head on my 850 mk3. I have a problem with the 3 bolts in front (the ones recessed into the cylinder head).
May Roadholder
Just received my copy, Very well appreciated too.  Enjoyed the SS restoration and the Article on head and camshaft lubrication .
