All Forum Posts
crankcase sump studs
On my Electra parts list there is a "stud for crankcase oil filter", number 24562. In the NOC shop lightweight twins section there is a "stud for sump plate but not MAG/SUMP", number 17399. Does anyone know if these are the same thing?
Classic Wiring Diagram
Hi everyone, I have decided to make my IP2 look Classic[ish]. I have what might be a Classic Wiring loom, the IP2 loom and An IP2 workshop manual. Can anyone help me with;
* do I have a twin rotor or single rotor model, how can I tell?
Clutch cable run.
When I ran the clutch cable to the gearbox it wanted to go between the 2 oil lines which is where I ran it, and it is up against the inner oil line after running it for a few hundred miles.
Navigator side stand?
I am thinking of fitting one of the side stands advertised in the NOC shop to my Navigator.  However, from experience on other bikes I have a healthy suspicion of how secure bolt on stands are, how well they hold the bike up, whether they foul the
Engine weight
Morning.  Just about to get my '47 Model 18 engine couriered up to Mike Pemberton so he can do his magic.  Can anyone tell me what it weights?  Thank you.
Jubilee engine parts
HI, picked up a jubilee in boxes at the weekend and i am trying to workout what is missing for the engine. I have assembled the engine to what i can see and make out in the manual but missing a few components for gearbox(later type).
mk3 850 carbs
I'm looking at replacing my MK3 Amal twin carb set up with either a pair of Amal premiers or a Mikuni single carb conversion, I must admit I do prefer the twin carb set up for originality and looks but I really want the reliability too, I have had
Running in
Having covered 250 miles the running in period seems to be going fine, a few nuts and bolts needed tightening plus an annoying oil leak from an exhaust rockercover which won't seal up yet. And of course head tightness checked at least 3 times
