All Forum Posts
Magnetic plugs
If you want a magnetic oil drain or sump plug you can buy a massive range of sizes and types of neodynium magnets on eBay.  I have been using them for years and they are stuck all over my steel workbench and racking units!
Motorcycle lock down
Hello - Now on the News the Government has now done a motorcycle lockdown  so if you venture out the chances are of you now getting a fine of 60 quid  for breaking curfew  and you be sent home or your motorcycle confiscated  So now its all a waiti
new member
Greetings from Norway.Looking forward to riding my recently purchased 2012 961 SE,still too bloody cold yet! Anybody else in Norway with a 961,regards Brian,in Skien.
Lost dynamo screw
Hi Guys - in making good use of the lock down I turned my tender mercies to the magdyno. In refitting it all I found the screw which holds the commuter end cap onto the dynamo, missing.
Oil leakage
I have completed 160 miles prior to the lockdown on a newly rebuilt top end of my 1956 Dominator 99 and despite re torqueing the head down after 100 miles there is a weep of oil from under the two rear top hex head holding down bolts.
rear rim
Having sadly lost my electra rear wheel when it was being transported (left on the side of the  road) I am now looking to replace it. I have been offered a wheel W M 3 -18 is this the correct one  I think it came from a Commando.
Inner tube valve nuts
Just got two new Avon RoadRider Mk11 tyres & tubes for my commando.  The new tubes have two nuts on the valve stem.  Can anyone tell me if one nut goes inside the rim with one on the outside or do both nuts go on the outside?  I have had a loo
Dolls head thrust washer
Hi all,
Can anyone clarify where you can get the hardened steel washer that is punched in to the sleeve gear and mates with the bronze washer on the main shaft these hollow in time but don't appear anywhere as a replacement.
Laydown mainshaft
I’m having trouble getting clutch clearance on my laydown box with a GT175 mainshaft ( it’s a single bitsa) does anyone know where I can get a GT165 as fitted to the twins?
cheers
Dan
650 mudguards
Hi all, hope you're all keeping safe.
Anyone out there had their 650ss mudguards chromed - would like rough idea of the price?.
I live in Leeds West Yorks so if anyone can recommend somewhere local that would be a big help.
rear shocks
Hi. What length are the rear shocks on an Electra from the centre of the top and bottom mountings and what diameter and length are the black shrouds. I would like the correct dimensions not an estimate please.
