Dominator 99 Crankshaft Drive Side Thread
Hi folks new member here needing some information on the crankshaft drive side, the size and pitch of thread as I have had a little accident.
All keep well and safe.
I currently have the cylinder head (cast iron) off my 1952 ES2 to repair a couple of broken fins. I was quite surprised to see a domed piston with the dome height above the joint face of about 1 cm.
hi what is the best spark plug cap in the limited space under the tank
hi ,i have a early 1961 navigator with the old type gearbox and the main shaft and clutch spider are worn , there are clutch spiders for sale on ebay for dominators does anybody know if the splines are the same or are there any other way of fixin
Hi, I have a 74 JPN that is missing the left side cover. Is it unique to JPN or interchangablw with another model. I purchased a mkIIa cover & its not correct. Thanks
I have a 1955 ES2 and the oil tank has a feed pipe connection at the rear of the tank, in addition to the usual outlet and return pipe connections at the front of the tank. Is this normal and if so where does it feed to? Unable to find any infor
I need to renew the Norton logo on the back of my Commando MK2a seat. I'm assuming standard waterslide decals don't work(?) and I need a stencil and spray vinyl dye?
After 2 valves seats dropped down and got smashed to bits and damaged the head and a piston,i decided to strip the complete engine and discovered that the right hand inlet lobe on the camshaft was badly worn.After looking at the cost of standard c
According to Indian media. 16 million for both the holdings company and Norton Motorcycles UK Ltd.
Hi all, an anyone recommend a good wheel builder in the Somerset / Dorset area who can supply a new stainless steel rim and spokes and rebuild my Navigator rear wheel?
Forgive by abysmal electrical knowledge but how can I tell whether my Lucas Altette horn is 6 or 12V?
It barely blips on 6V but on 12V it is super loud albeit very raucus.
Looking to buy a complete new set of exhaust pipes and silencers for my Roadster 750.
Has any one ever modified the chain drive to the camshaft to be gear driven
Having trouble with the thread on the crown lug even with a new adjuster nut for the head bearing from n o c . It is unbelievable how both old and new nuts are so tight.
Yet another query - sorry. Can someone advise if there’s supposed to be a gasket between the oil pump & crankcase please on a late Jubilee.
I'm working on the lads Marlin which has a badly blistered laquer coat. Going to respray but removing the laquer from delicate areas is proving difficult without finishing up in the glass matt. Any ideas?.
I have a Norton model 50 single, 1957; could anybody advise the correct battery for this bike and a serial number? I’ve been told that it hasn’t been converted and that it’s a 6volt large. This is all I know. Many thanks
Dave
Having read Niell Watkins article in April Roadholder it seems I could have a problem with the crankshaft seal. My spare parts list shows part D12/931 but does not indicate location and my maintenance manual is likewise blank.
So after last Saturday´s ride which ended in an oily mess around the bottom of the bike I followed Nick´s advice to check the oil level. Oil tank was almost empty.
From various discussions about front brake LH or RH side and earlier one over speedo cable routing. Andy Sochanik put two photos on another post (Navigator Silencers) of post 64 Jubilees - one a USA returned original & a period advert.
Hello Now we have had this big argument before Now has you in the south call Luton middle of the country were as we lot call York central of the country when you take in Scotland that every time gets left out the Top link A4 And A3/A1peppercorn st
In the course of rebuilding my Inter motor, I bought a vernier mag sprocket from....now I can't remember, must have been at least 5 years ago. It was listed for long stroke Manx(not showing # of teeth) and my parts books showed it as the same par
Does anyone know if any info exists on the positioning of the Atlas 750 transfer on the top of the petrol tank. Been hard to find any decent pictures online.
Have a look at the attachment showing a 961 for sale on eBay. Below is part of the blurb in the description. I think a grammar checker might have come in handy!!!
Where is the best place to look for constructions kits, plastic or metal, of classic motorcycles, particularly Nortons ? Both real bikes ready to go, so need to fill my 'lock down' time !
Hi Guys - how do I upload a short video clip from a Mac computer?
I haven't tried it yet so it might be quite straightforward.
George
Hi all, I am thinking of replacing my late Navigator silencers and down pipes and see the NOC shop sells the late silencers made by Brituro who I have no experience of and can't find their website on line, A search on line shows Feked sells the c
Hi All,
Boredom is setting in and I have decided to smarten up my 650.
It is standard slimline without the chrome tank badges and is currently metallic silver, but it needs a respray.
Yes those lovely bowls that sit under early Manx tanks. I’m lucky to have a pair on my machine but sadly one weeps fuel from the taper valve. Cleaned,lapped and polished butt still weeps.
