All Forum Posts
Dommy to the rescue
Our Elec Sub Station Expired with a bang .  Oh dear the phones and I pad need charging,  Astonished looks when I said plug them into the 99  and leave the door to the garage open to hear the phone ring .  No problem !!.That accessory socket has be
ups delivery problem
hello spares  team now it looks like my order will not be delivered  as ups as never delivered here before  and they use GPS  and were not on GPS or the map for some reason only the postman has the keys to our post box      all deliver drives have
1939 16h WD
Hi. Has anyone got an exploded view drawing of the 16h engine which shows where the location of the ball bearing and the light pressure spring locations are. I am rebuilding a 16h from a box of bits.
Navigator Engine Rebuild
Can anybody Help. I am rebuilding a Navigator engine and would like to know what is the gap between the barrel and the cylinder heads i.e. spigot height as the heads have been skimmed and at the moment there is a big gap many thanks.
Lay down gearbox
 Hi everyone,
                  I am stripping down a lay down gearbox on my 1954 ES2. My problem is that I am trying to remove the cover over the kick start shaft spring fitted to the outer cover part no A2/358
4 month lay-up
Hi Guys - What's the consensus of what we should do with our prized possessions for the next 3 or 4 months? Obviously drain out the oil to obviaye wet-sumping  bu what about the fule tank?
Model 18 valve timing
Hi all I'm about to rebuild my 1929 model 18 engine, has anyone got any tips on setting up the valve timing gears, there are no timing marks and they all fell out when I removed the cover so I was unable to put my own marks when I stripped it.
Mk2A Ignition switch
During almost 30 years of owning my Mk2A Commando it has consumed 5 Lucas ignition switches! It must be the least reliable item for what is a very basic role in life - with not even a starter motor to energise.
drive side nut
hello can anyone tell me the thread size of the drive side nut that holds the rotor and twin-row sprocket in place  and were I could get a  spare one         yours anna j
Insurance
Hi folks just had my insurance renewal quote from Carol Nash who I've been with for years, 2 bikes, Commando and 81 XT250 £2OO. bit dear methinks, so I was up my local M/C club W. A. C. (Worcester Auto Club) and a few of the lads are using R. H.
