aarrrggggghhhhhh!!!
stopped by the machine shop yesterdaywhere the cylinder was left 2 weeks ago to see how it was coming. he said he thought it would be finished this week. great!!
Hi There
Ive just joined this club because i think i might need a lot of advice . my father in law has just given me his 1938 16 h Norton , he was going to restore it but due to ill health he cant
Does anyone have a camshaft breather assembly, the one for my engine is missing. Thanks
Hi i am putting my jubilee back together before the final repaint, i have the centre stand fitted, but i cant see where the spring anchor plate should fix to.
Anna want to know if i its safe to run my bike with the drive cover removed for a few weeks whilst I have it chromed 4-6 weeks
Hope you are well. Russ
I have a 1956 dommie 99
I've recently had my mag completely rebuilt and now the bike is reluctant to start when hot.
Has anyone got a suggestion regarding the fitting of a later type propstand (mk3 850) to a 1972 model 750 frame as mine has lug type (no bolt fitting) as wife gets fed up kneeling down and getting it out for me ? Regards Alan Nortiboy Johnson
I am looking to send my bike off for painting soon and was wondering what transfers there should be on a thirties Inter. I have the ones for the sides of the tank, but should there be one on top?
Hello,
How much of dominators (7,77,88,88ss,99,99ss,650ss,Mercury,P11,N15 et Atlas) was built by the factory Norton ?
Thank you.
Hello all, does anybody have or knows of the whereabouts of a dvd for rebuilding a commando engine. I have googled this but havent come up with any info ( except arnie shwartznegger) to purchase one.
Many thanks
chris r
I have a pre-war inter with the rear set footrests on it. The footrest currently gets in the way of the kickstart that came on the bike.
Does anyone have a 1946 Model 18 clutch case or know where I could get one?
My recently rebuilt Commando smokes heavily on the right cylinder upon start up. This clears after a short while. The bores were on plus 20 and not worn. I glazebusted the bores and fitted new rings.
My friend bought a 1959 Dominator 600 in England 2 months ago, this bike has been completely restored by the seller, now after 120 miles running, there was a great noise in the engine and a lack of power.
Hi guys,
I have just purchased a 1977 Mk3 electric start commando, unrestored and reasonably original.
The rear disc was rubbing against the side of the caliper, exhaust side.
Attached pic shows the source of an oil leak below my ES2 crankcase next to the primary cover/alternator.
I noticed in my '57 norton parts book, that the model 19s rear fender has a different part number than the '57 model 77 , why is that? The both use the single downtube frame.
Skip
While making my purchases at a plastics supply shop near me. I asked about fiberglass fuel tanks and why alcohol seems to degrade them, I was told that the U.S.
I am a way from needing this part, but I am going to need an indicator switch for my Elactra. Searches for part number do not seem to reveal anything, and I have no idea what the switch even looks like.
Completing rebuild of Dominator. Time to seal tank. Whats the latest views of types of sealer to use and where to buy from?
Les
hi guys ,new to the commando ,i have a 850 electric start but its a lazy starter i have fitted a 4 pole starter but this just turns the engine over half a dozen times without firing,am i expecting too much from it,it will start first kick so there
Hi, does anyone know where i can get some stainless pipes RGM,Norvil don't do them,any suggestions ? I have stainless Reverse cones 1" 3/8 with roadster type mounting brackets.
Many Thanks Dave T
Hi Alan - we met at the NMC on Sunday for the NOC AGM and I was admiring the mobile phone mounting bracket fitted to your 850 - you stated it was from Maplins but I've looked on their Website and can't find what you have fitted - can you perhaps c
Most references I have found regarding Mercury production years indicate that they were made from 1968 to 1970 with the serial numbers of the production run (approximately 925 motorcycles) clearly identified.
Hi has anyone successfully jetted a VM36 carb to a 850 Commando, mine either won't start or fouls plugs too often to be safe.
Hi, I have just purchased a Manx and would like some pointers regarding the frame and its identity, the Machine has come from overseas and I am advised that is has remained unused since the 80's, the original frame number [if it is] has been overs
Hi Everboby "Happy Easter" Iwas given a primary cover i think off a 750 fastback ,it has an oil take-off hole near the relief valve.I think it could be fastback because 1; i purchased a early frame off a person (frame no 135285) he also has a f/b
