Crankcase sealant
Has anybody any historical evidence to favour a particular sealant to use between crankcases? I think I last used a silicon based sealant, probably Hermatite instant gasket.
I am restoring a 1938 ES2 and am at the engine rebuild stage, although on dismantlingI marked the cam wheels and pinion, during the cleanup stage these marks dissaperared!
What is amacceptableamount of side play when assembling 750 commando conrods.
kyle
Hi All, Quick question. Do I set my air screw and hence idle speed with ignition fully retarded or at the midway point which is recommended for starting ? Amal 76. Can't seem to find a definitive answer.
Glenn
The Shropshire Branch Camping Weekend was a resounding success with precisely three non branch members making the effort. (Interestingly, all three were on Rotaries, Thanks chaps ) I won't bore you all with the details of what you missed.
Hi Guys, I have a 1943 16H and I can't find out much about settings etc, is the ignition timing the same as a '39 model, also the tappet clearance?
I haven't received the May Roadholder - canI get a copy sent ?
Tank sealant for Commando fibreglass tanks - has anyone found a reliable product yet?
Thanks Pete Mietus
hello every one last night was a good one as we had two new member sign up and there was 20 or so member there on the night we finished of the night with sandwich's and a talk with each other , a good night was had by all ,we need to keep up the g
Just purchased a RGM Motors solid state alternator rectifier regulator which I intend to fit to my 850 MkIII, and am not sure how to wire in
Having recently acquired a Dominator 88 I'm currently trying to make sense of the seemingly impenetrable world of cylinder heads.
Just got the MKIII out yesterday to check it over and clean it before the MOT on Friday.
Hi All, need to replace the clutch centre cush drive rubbers (AMC clutch) This looks like a real fight. Anyone got any good ideas of how to go about this? Thanks Rob
Does anybody know if the tapered head race bearings in the NOC shop are a direct swap for the cup,coneand ball bearing type with no machining requirement, thanks in advance, Mark
I have a master cylinder with the plastic lid and was wondering if the earlier alloy lid would fit or does anybody know where I could get an after market alloy lid that will fit the later type master cylinder
I need the timing chain case both halves for my big 4 or someone who can get one cast for me.
Also a pilgrim pump for the same bike, And a sturmey archer gear leaver.
I'm wondering if it's a practical proposition to fit a kill switch to the Lucas MOIL magneto. It would be really useful to have such a facility, but I can't figure out what one would earth in order to kill the mag. can anyone help please?
Hi, I need some advice on how to get a gear off my crankshaft... I've split the crank cases and pretty much everything is now off apart from one gear on the end of the crank.
I'm overhauling the Roadholder forks on my 1957 ES2 and it's clear that I will need new bushes and seals. My illustrated parts list is proving useless as usual (the parts numbers used don't seem to correspond to any others in use!).
I hope to be able to attend this event. So far, the cheapest, and quickest, way of crossing the channel seems to be via the tunnel. Once off the train, it should not take much more than an hour to reach the site. Anyone else taking this route?
The new Yorkshire branch web site is up and running in the new format. We were unable to update the old site so it was dormant for a number of years. The new site has lots of details aboutthe branch and the activities that we undertake.
This topic has probably been beaten to death, but having gone through old posts, I haven't found out what kind of plates others use in a belt drive primary case. So what do you folks use?
Having returned to Norton ownership with the acquisition of a featherbed Model 50 I find it dispalysa film of oil around the barrel and upper crankcase that would seems to be coming from a cracked and ill-fitting tappet adjustment cover.I understa
I would like to arrange ventilation in my primary chaincase to keep the belt drive cooler.
Has anyone had this done? What pattern of ventilation works well - holes? slots?
I know its a well talked about subject but can I ask foropinions on what are the best options to cure wet sumping on a750, ie. is it worth fitting the late type timing cover as per 850's, or an oil line valve, tap orwhatever?
I'm in the process of refurbishing a '58 Dommie and will probably be picking your collective brains in the coming weeks.....(hmm....months more like).
My 16H needs a new small end bush. I ordered one from a trader on eBay. The advert photo clearly shows a copper coloured bronze bush, but the one received is brass. They say this is correct, but others list bronze.
I have tried a couple of times to email members/send messages from the site by clicking on the poster's name. I get a "Form" to fill in with space for a title and a space for text. I fill these in and the message is refused.
Does any body know where I can get the surrounding alloybezel for the Lucas headlamp medallion .?
I ordered a new medalion from RGM and it came without the surround. They can not get them.
