All Forum Posts
Goole Hobbies Exhibition
Hello to All Goole Hobbies Exhibition , Is on March 3rd from 11am at the Leisure Centre North Street ,Near the center of the town ,The East Yorkshire Branch with be showing there machine there representinging the Norton OwnersClub yours an
Sparkplugs
Hello to all Sparkplugs for Magneto models only , I have found that Bosch W7DTC ,from www.The Green sparkplug.Co Heat Range is the same as Champion N5/N6Y and Have NO resistors in them and give's better starting and a cleaner exhaust and s
Rear brake rod colour?
Hi, Can anyone help me with this one?
Big 4 / 16H the late models (early 50'ies).
Were the rods chromed or painted black or something else?
The front end of my Big4 rod looks as if it had been chromed?
Gearbox
i am looking for some advice my norton commando 1974 with the spark plugs out i can turn the engine with the kickstart but with plugs in it does not catch inside the gearbox the spline on the shaft and kickstart is good
Norton ES2
Please does anyone know if my Norton ES2 Tank would have been painted or chromed its very close because of nickel at the time.Date of purchase; 31st August 1951 (left factory) Engine & Frame No 40483.
Manx GP 2012
As I have never been to the Manx, I have decided that my re - built 850 should take me and the missus there in Aug.
International Rally fees
£41 for the International rally for two nights camping and rally fee seems a bit steep. (that's before I've eaten or drunk anything) Is this a way for a branch to swell it's bank balance? Maybe the EC could authorise a subsidy.
'71 Commando cush drive
a friend with a '71 commando that he recently purchased, came with a rear wheel that was the earlier type with no cush drive & the 3 sleeve nuts. Now the bike was semi assembled & the wheel itself was notinstalledon the bike.
19S engine sprocket size
I have a 1956 19S which was puling a sidecar. I am now running it solo. It presently has a 19 tooth gearbox sprocket and a 19 tooth engine sprocket. Should I change to a 20 or 21 tooth engine sprocket? Does anyone have any suggestions?
Oil pumps
I bought a 1960 99 to restore and decided to start it to get an idea of what didn't work or might need doing before stripping. It started fairly easily and there were no nasty noises.
Oil pumps
Torque figures
Has anyone a list of torque figure to use when rebuilding an 1954 ES2 Engine, mine is an alloy head, and any must change bits when re-building the engine?
Charles
Combat head
Hi one and all, i have a 750 commando head ,which i was told it was a combat head .It does have a c stamped between the exhaust covers and the head surface is well machined (high compression).
961 Sport screen
Has anyone fitted a 961 Cafe Racer Flyscreen to a 961 sport, it looks like it should fit OK but have not seen a Sport with a screen fitted. If not is there a suitable screen available to fit the Sport?
