1946 Model 18 clutch case
Does anyone have a 1946 Model 18 clutch case or know where I could get one?
Steven,
What do you mean by clutch case? Do you have a picture or a Part No.?
sorry i mean the clutch case cover as when i pull the clutch in it scores the iner case ?
i dont think it had the right one as standerd . i have even putt some washers to see if that would help ? dosen't.
The Norton 'Oilbath' chaincase doesn't leave a lot of room between the chain runs to ensure clearance on the back and front of everything. However, if the problem only occurs when the clutch is lifted and everything there is up tight then it suggests that a worn mainshaft thrust washer is allowing the whole assembly to displace.
If you can grasp the clutch (or mainshaft) and pull it in and out more than a fraction then you'll probably need to delve into the gearbox.
It is worth checking that you have the correct clutch. Anything made up using the later friction back-plate or alloy pressure plate will give clearance problems in a dynamo model chaincase.
