Amal 76 carb problem
I'm having trouble getting my 1938 ES2 to idle due to to lean a mixture. Before I go any further I will tell you that it has a 76/012 carb fitted which was originally put on the 350's. Es2 500's had a 76/022 originally.
hi sadly i find my self in the position i have to sell my much loved dommi she is fully mechanically restored using mostly original parts so she dosent look perfect as in the paint isent very good and if the chrome is warn then so what id rather h
Hello all - my Mk2A 920 is now run-in and running well. It's fitted with 2 x new Amal Concentric 32mm Mk1's - no air filter but 2 x Bellmouths with gauze filters. I have one issue - to enable the engine to 'pick-up' cleanly from idle (i.e.
Don't think it's carbs, just fitted a pair of new Amals. Starts and ticks over sweet as a nut. On a run it starts to feel lumpy after 5 miles or so. Slow down through a village or a series of turns then the problems really start.
I need to do a minor touch up to an otherwise immaculate frame & re-paint the whole of a prop stand, both in black
Hi all,
I wonder if anyone out there can help me identify a problem which only cropped up last Sunday, 400 miles into running in my newly refurbished ES2 motor.
My Dommie has done about 30,000 miles since it was rebuilt. The chrome wheel rims are shabby (a tom cat peed on them in the shed at least once...) and stainless would (I think) look a lot better and last better also.
On a 1948 ES2 could any give me the correct size for Plunger Springs (top and bottom) and if they have any idear of where they can be obtained many thanks
Just aquired a 1968 Norton Dominator which requires restoration. My initial plan is to get the running gear (engine, gearbox etc) sorted by proffessional restorer.
Hi All, another question I'm afraid. Can any one tell me what the rim size is for a 1960 es2. I need to order new stainless rims, the old ones are pretty tatty.
Please note that the International Rally 2012 (In Skipton between 6th and 9th July) details are now listed on the Yorkshire branch web site. A full programme of events has been set up for rally visitors.
Hi all. Back in the early 90's I had an oil seal conversion done on my rev counter drive housing. This conversion was done by Fred Barlow of FBS motorcycles. The seal has worked magnificently until now.
Over years of commuting on my Mk 2aI found that the ignition contacts for the lighting circuits spark erode. Now that I am putting it back on the road what is the recommendation for fittingrelays on the lighting circuits?
Am seeking information as to what cylinder compression I can expect from a Model 50. I have measured a max of 110 psi on mine after a dozen or so kicks.
Hi all,Do all dolls heads have 4 gears? If they did a 3 gear one would it be nuteral at the top, first, second, then third? how do I tell from the inside if it's a 3 or4, Please help, cheers Tony.
Hi All,
I am looking into a friends JPN Commando & trying to get as much info as possible.
I've stripped the clutch on my inter and although I was planning on geting the end plated it looks quite corroded in places so wont come up very well. The sprocket and clutch basket are also quite worn and very rusty.
Good Day
Getting started with my first Norton restoration, a 1935 ES2. I have been unable to find out whether my bike (engine number 62349G)had a 19 or 21" front wheel. Any help would be appreciated.
John
O.K. not strictly "Norton" but may interest some.
where in essex is agood paint man for petrol tank
Hi all - I have a 920 Mk2A Interstate fitted with a RGM 32mm Belt Drive Primary. I have just received the bike back from the Motorcycle Restoration Company (located in Saffron Walden, UK) following them fitting the Alton system to it.
Hi, I need to know which wires to fit to which terminals on the ignition switch of my 1975 850 electic start, the switch has the terminals in a circle with one larger gap then going clockwise one joined pair, one single terminal then 2 joined pair
Need to replace my cracked cylinder. 1947 16H please help with part or referral.
Thank you
Werethere various types of centre stands for the Dominator manufactured during production?
Hi
Can anyone send me a close up of a tank finished in the Golden Bronze colour scheme so I can see the correct size of the metal-flakes?
Hi folks
what is the correct way to remove the front fork assembly from my 16 h
i dont want anything else to break
Billy
Last summer I sold the above bike at Beaulieu auction, but dear Bonhams either would not or could not pass my details to the new owner.
Joined the Vintage club. Hope you get it fixed before everyone leaves.
I am restoring a MK3 and have come across a problem with the gearbox.
I have setup the quadrant and camplate and have checked I have all gears inner cover off and on.
