Hi, I have an 88ss head with wobbly rocker spindles. Has anyone had a head bushed to cure this and if so do you have any recommendations for someone to carry out the work? It's a bit beyond loctite and the RGM kit.
cheers,
pete
How bad is bad, it might be…
Thanks Ashley. Too bad I…
Thanks Ashley. Too bad I think. The inner bores have worn oval. I'll have a proposer measure up shortly. Were the bores reamed for the larger spindles?
The worst is the inner bore…
The worst is the inner bore of the LH exhaust spindle. That has 0.018" up and down
Specialist Engineering
Discuss with a local model engineer or toolmaker? Your local NOC Branch may have some contacts? Whereabouts in the country are you based?
Mick Hemmings has gone; Norman White has retired, and it sounds like Mike Pemberton might have too? SRM are still going though. Who have I missed?
Pete Lovell
However I have heard that he is retiring, or may have even done so. Getting some things done is getting increasingly difficult.
Thanks people. I've…
Thanks people. I've contacted SRM and waiting for an email reply.
it looks like I'll need to tackle it myself.
SRM have come back with a…
SRM have come back with a reasonable quote for what is a tricky job. It's still a hefty amount of money so I've got that on hold while I have a play with doing it myself. Bought a damaged head from the NOC shop for £25 to have a practice on.
How bad is bad, it might be possible to get some oversize spindles. I had some made some years ago in +0.005 and 0.008'' who we sold them too might still have them.
