Model 18 oil pump
Hi again, I'm having trouble disassembling the oil pump on my 1929 model 18 , the only markings on the pump are "BEST" has anyone had any experience in overhauling one?
Thanks Simon.
Thanks Simon.
Hi everyone, I'm after a set of rings for a 1929 model 18, the piston I have has got 3 rings all the same. The bore and stroke is 79X100 dose anyone have any ideas thanks Simon
Hi
Can someone give the length of the front mudguard spacers that fit between the U bracket and the fork legs
Thanks, Steve
My 71 commando started cutting out on idle so I serviced the twin carbs (new jets, floats etc). The problem remained and then I noticed that the LH exhaust was hot fairly quickly after starting but the RH exhaust was cold.
Is there a side stand for the Model 18 Rigid frame?
Changed my bike from 6 to 12 volt. Do I have to change the 6 volt ammeter to 12 volts.
John.
I have a new wiring harness and a fairly new 12V 6A battery on my Electra which reads near 13V with no load and drops to just over 9V when the starer is engaged. Should it fall this far?
Although the pistons appear fine and run quietly I have found that the top rings appear to have too much clearance in the grooves (at least 5+ thou) 2nd rings about 4 thou, Was thinking of replacing rings but the new ones are no thicker so the we
I have removed the front Isoelastic engine mounting. The rubbers look shot although I havn't removed the rubbers yet.
I an helping my brother-in-law with the rebuild of what is effectively a late 30s Model 19 engine.
Hello I have 650 SS year 1964 and I have this tachometter RSM 3003/00B i want to buy tacho drive.
which type to choose? and whitch turn?clockwise or anticlockwise?
shaft on timing deckel turns anticlockwise
Hi all - Can anyone confirm the internal thread size for the Rocker spindles - near as I can tell it seems to be 5/16 UNF 1972 manufacture 750 combat cylinder head . I need to make an extractor - Thanks for any help
Richard
Can anyone help with my rear wheel problem. I need to know if it should be respoked off centre and if so by how much.
In anticipation
Craig.
Anyone used a non-original starter on an Electra? Are there any known sources for replacements?
I am considering fitting a full flow oil filter to my 1956 Dominator 99. Any advice as to which type and are there any associated fitting problems ? I note that there are kits available for the Commando.
George
I am having issues with the monobloc carb on my 1959 99 whereby she will only run with some choke on and has no power going up hill. I have cleaned all of the jets, raised the needle and adjusted the air screw, all to no effect.
Does anyone know the weight of a std original Atlas piston?
Yesterday I had the opportunity to compare the starting effort of my 1956 Dominator 99 with my friends 1955 Dominator 88. The 88 which has a newly built engine started easily with just a gentle to firm ‘ prod ‘.
Looked at every illustration that I can lay my hands on and can't establish what I need. Can someone please give me some information about the gap between the end of the gearbox mainshaft and the back of the clutch drive sprocket.
What's the best blast media for removing the old paint from my Jubilee enclosures.
Thanks John
I have never had this done,I quite like the used oily look. Son want's to tart up the scruffy Atlas and we are thinking of getting the head done and barrel stripped for painting.
Hi, Im not sure if I have missed something, but I wonder if it would be a good idea to have response notifications to our posts on here. Like one gets from facebook etc, when someone else comments on our posts on here.
Sorry for the barrage of questions!
I am thinking of getting an alloy clutch basket and oil-proof belt.
I have some used fibre friction plates in superficially good condition albeit a little oily.
Any recommendations for a decent quality petrol tap for my Dominator 99 ?
We managed a dozen last year at the locals branch of NOC annual bash , so mark it in your diary & pop along for old & news in the same place , let’s see if we can manage some dominators this year
Hi I have been let down by my first choice of repair outfit. Apparently my bike is "too much hassle".
The Atlas reg 68,eng no 1252257P has been in the family for 20ish years,Bought in Kent as a rough non runner it came with worn twin concentrics and an older dommy? mag.
