All Forum Posts
Sump drain
Hi all, first post as I only recently acquired my Mk 3 850. It has a few issues so getting to these one at a time, a couple of questions if I may?
May Roadholder
Sorry all, but due to circumstances beyond my control, the May 2019 Roadholder dispatch from the printers has been delayed such that you may not receive your copies until next week (w/c 6th May).
Timing case
 Does anyone know how many different covers there are? I have a late type with the three bolt mounting  fitted to my ES2, I wanted to swap it with an original type so I can fit a mag dynamo,.
Big 4 Fork sliders
Hi I've just started working on the forks of my 1950 Big 4 restoration project and hit a possible big problem. The fork slider are excessively worn around the spindle holes without I think enough metal remaining to ream and sleeve.
New rings
I.m fitting new rings to the Atlas and have been supplied Wellworthy 5 piece oil rings but with no instructions .  3 rails and 2 springs per piston (RGM supply these too)  , Information on end gaps and the position of the extra rail would be usefu
Bar End Mirrors
Has anybody fitted aftermarket bar end mirrors?
i have a commando street with renthal bars and struggling to find suitable mirrors due to the narrow internal diameter approx 16mm of the tube
any suggestions?
