All Forum Posts
51 es2 rocker oil feed
Hi all, could someone please tell me if oil feed to rockers only lubes the shafts or should oil travel  to push rod end through drilled hole which is blocked, and I mean blocked, not with crud but what appears to be steel.thanks a lot,Mick..
Dominator clutch
Hello can anyone help me I am building a 1956 Dominator  but it has seperate ferodos in the clutch drive sprocket / basket do they just push in or do they have to be factory fitted and is there different sizes my ES2 is the later bonded type
Engine reconditioners
I need a re-bore and some head-work on an 850 twin engine. I live in Warrington Cheshire UK. Anyone out there have a preferred engine re-conditioners that they use in the North West? Reasonable rates.
Just curious
A friend of mine has a 1955 Dominator 88 of which he frequently says that with its rebuilt engine it starts easily with ’ just a  prod ‘ of the kickstart lever.
1950 Big 4 - PMU 763
Chris Reynolds who was a founder member of North London Branch has found the old log-book to the Big 4 that he once owned and would like to pass it on to the current owner (He posted on a Facebook group).
VIN PLATE
I need to make up a new vin plate for my 74 850 commando has anyone got a photo of there vin plate fort this year as they seem to be different also size of stamps
Jubilee bulbs
My bike is 12 volt. Does anyone still do m.e.s. cap bulbs, the book says its 3 watt. Also need bulb for the speedometer  which is 1.8 watt.
John.
