RGM Norton front brake upgrade
Hi, I am thinking about upgrading the front brake on my 73 850 Roadster using the RGM Lockheed racing caliper kit.
Almost the last job before finally being able to start the build up of what was a sad, butchered Mk3 wreck (approx. 60% had to be replaced or was incorrect/not present) is to refurbish the fork yokes.
I'm rebuilding a 99 600cc (SS?) and just taken the barrels off.
You can see the damage in the attached photos.
The pistons are stamped +020 so it's had one rebore. From the cylinder scoring it needs another.
looking for somewhere I can get hold of a trip reset knob for my 1973 750 commando. fits from underneath and not the side. does any one know if they are the same as the side type, wondering if I could buy one and somehow lengthen it..
Hello I have a 54 Norton 16h, a while ago it started backfiring through the exhaust when the throttle is rolled off, it’s very annoying and even more annoying to pedestrians, I tried resealing the header pipe and it was no different, the timing is
Can anybody advise the correct length for an Atlas exhaust valve? I believe they are the same as the Dominator as the parts list indicates.
Thanks.
This morning I pulled the crankshaft apart on my barn find Domi 99. In a previous post I mentioned that a large chunk of the drive side oil seal support face in the left-hand crankcase was missing.
On my 1964 Atlas with boyer ignition and regulator/rectifier + new battery, with the engine running the ammeter shows no charge.
Bonjour
Quel espace entre vannes pendentif de vannes/guide EX-IN 16H
Merci
I'm in the process of dismantling my 1936 Model 18 and find the valve gear in a poor state. I'd appreciate some help on the following:
After seeing the state of my Domi 99 engine I’m starting to question every item in there.
Anyone know the part number and a source for a set of Electra rear chain adjusters?
Jack
I am rebuilding a 1961 ES2 and the two speedos which came with the parcel of parts are:
1. Smiths Green Circle 150 mph(!) SSM 3001/02 1000
2. Smiths Grey Circular center 150 mph(!) SSM (5001/06 1000)?
See photo
morning all,
Can anyone tell me what tests I can perform on my pvl 6v coils to ensure they are ok? Currently trying to troubleshoot dodgy spark from plugs.
dominator 99 1962
cheers
Noticed that most of us can't make a clickable link in their messages, but some can.
How?
Hi I have obtained a NOS Hepolite 71 MM +.040" piston Cr 7.25 TO 1
My cylinder is off for to have a cylinder liner fitted and the machinist wants to know what size the bore is to be finished to ? Can anyone please advise ?
You don't see one advertised for years then three pop up at once, John Player Norton's that is. What's surprising me is that they don't appear to be attracting any buyers.
Just for historical accuracy does anyone know what was in the toolkit sited under the seat, got the tool tray but no tools!
Whatever happened to this project? Mentioned, several times, in the celebration booklet, it seems to have quietly passed away.
I have a Norvil head steady fitted to my 750. I keep getting told that this is possibly the reason for some hi frequency vibration. I am not a knee down scratcher so prefer smoothness over rigidity.
- Revert to standard
My 750 seems to rev much higher than my previous bikes. 60 mph is about 5500 rpm.It almost feels like I need to change into 5th I have a 19 tooth sprocket and a Norvil belt drive.
- What is the standard tooth number for 72 759?
As rally goes will know, we try to create a 'Book' all about the rally. The final version will be printed out and given to all rallyists when they arrive but you can find a draft copy of the book here:-
here we go lads.....take a break grab a cuppa put yer feet up and watch this......Stan 'The man' Woods......Nortons Bestist ever Works Rider........LOL
At last! Some time ago the NYC very kindly gave everyone free Commando 850 side panel stickers. Not owning a Commando I dithered on what to do with them. Today I found the answer!
My apologies!
Greetings,
See enclosed picture from my 1961 M-50.
I have lost the rubber 'waterproofing' cover from the combined ignition / lighting switch.
Are these available, if so from whom / where or is it a make it yourself job?
just a quick one to thank the guys from the Northants and Leicester branch for their invite and welcome at the meeting today - Wharf inn Welford.
Hi all -
I am preparing to replace valve guides in my 1972 manufacture Combat cylinder head.
What is the correct handlebar for the Roadster?
Nick
