Is there or has there ever been a Norton Registry? I am thinking along the lines of Each particular machine belonging to a group, say Manx Norton Registry, then year, model etc. Certainly for the rarer models at least.
I have a 1959 Norton Jubilee. Hopefully I will have it on the road soon.
Does anyone know of a handlebar mounted speedo other than CNW expensive one ? also has anyone fitted a Brembo 13mm master cylinder and where could i source one in the Uk
I have a 1974 850 Commando fitted with a single 36mm Mikuni. It is has the stronger return spring fitted. Earlier this summer, I was at the Dijon circuit for the classic bike track sessions.
I'm new to Commandos as I only bought a 1970 750cc this year.The bike has only done 3,500 miles now but wet sumping is an issue. It wetsumps much worse than the 650SS I have ridden for the last 30 years and also much worse than my 1952 ES-2.
Can anyone tell me what the speedo cable length is supposed to be for my 1961 Model 50?
The correct part number is: 19367
A 69" cable is way too long.
Does anybody know where I can get a set of screws for the timing covers and primary chaincase? Cheers,Mick.
Some timeago I put Mk3 isolastic conversionson my Mk1 850. The bike seems to have more vibration at low revs than with the original type.
im looking for a right hand side tank badge for a slimline petrol tank and would apprieciate anyone who could source one or a pair if nessacery.
I recently bought from RGMa muffler (silencer) for my Slimline Model 50.
I ordered pn: 22121 which is the correct number from the parts book.
Over the 40+ years Iâve been pulling engines apart I have amassed quite a few pullers.
My Commando has developed a misfire sometimes at low revs, and runs fineup to 4k where it refuses to rev beyond that.
Hi
Used to be a member years ago, had a MK 111, stupidly sold it 5 years ago.
I'm getting another Mk 111 in a few weeks, the engine and gearbox will need a rebuild, any recommendations chaps?
what would be the recomended engine oil to use in my dominator 99 of 1960 vintage. I have a gallon of monograde sae 50 that came with bike but it does seem rather thick. Any comments gratefully received
Jim Dracup
Check out this site:
The first part are general pictures, then it gets to the good stuff.
The nextplanned Yorkshire branch ride out is on Saturday 25th September, this will bethe branches last planned ride out in 2010, the destination is Matlock Bath.
I'm recommissioning a Mk111, and I've just replaced the rear wheel bearings (3), oil seals etc.
Hi Guys,
I'm a new member, well a rejoiner after 20 year + absence.
On my third Commando,
Have the read about this in the Technical Section under "Smoking engine" and I really can't get my head around how this helps.
can anybody tell me if a amc kick start leverwill fit a laydown box on a 99 dominator
I was recently checkingfor previous bikesI had owned on the DVLA site.
The only luck I had was with my, bought new in 1972, Norton Commando Roadster, tangerine petrol tank and 2LS front brake, reg: PLA 454 L.
Hi All.
I'm trying to trace the ownership history of JOF 814 1948 ES2. I have the factory record but no other information. Any information will be gratefully recievd.
Malcolm
Hi, can anyone help? I'm in need of a bevel drive gear that fits to the crankshaft for a 1957 500 Inter. Mine has less teeth than it should have and is the only part needed to complete my engine rebuild!
hello, for the acquisition of the 88 SS norton 1964 serial number 88 SS /107207/P
I not known if the number corresponds to a model 88 SS 1964 ?
tank you for answer . cordialy . bernard (norton owners club French)
Hi
Has anybody got these fitted to their Commando ??
I`ve used these before on a Duke but they were louder than standard
what noise level/sound is like using them on a 750 Commando much appreciated
Club members (and anybody else) travelling to the USA will benefit from applying on line for an ESTA (Electronic System for Travel Authorisation) to assist in travel to the USA.
Having last week acquired a very nice '53 model 7 I'm interested in improving the front brake performance.
I require a petrol tank for a 1950 16H Norton. It must be in very good condition with no leaks. One restored or a contact as to where I can find a new one.
