All Forum Posts
Re: Norton Jubilee info.
Hi i have bought a jubilee in a million pieces, i have started with a quick build to see what is missing, can anyone please help me with the following.
Should i have just one piece of a rear mudguard, and should there be any stays.
Horn, repair or replace
Having just had an MOT failure on my Mk III due to lack of noise when horn button was depressed, I set about trying to establish it's location. Half an hour later and with the help of various manuals I spied part of the outlet trumpet.
Cam Timing
If there was anyone interested enough to try the worksheet? My post âFor the weekendâ this attachment may help; Iâve rewritten it for MS Works, a more common Spreadsheet. Itâs quite safe to RUN.
Model 50 Air Cleaner
The parts list for my 1961 Model 50 lists in the back pages an air cleaner pn:18684
Does anyone have one that could post a photo?
I cannot figure out how it would be mounted as the carb comes quite close to the oil tank.
Rear Wheel Bearings
Hi all - at the recent MOT for my Mk2A Commando I was issued an 'advice note' that the rear wheel bearings are 'tired' - this was a warrented comment as there is some play in them. I've never tackled the wheel bearings on a Commando - any tips ?
Primary Chain
The primary chain on my 1960 Dominator 99 does not seem to last very long. I ride the bike regularly and with some 'energy'. I have just replaced the last chain after 3600 miles with another Renold 'Synergy' 1/2"p chain.
Paint codes
I see on this site that the paints given for my Electra tank and oil tank and toolbox is "Ford Silver Fox" "GM25411". I went to an automotive paint supplier, but he had no idea what these mean.
For the weekend
On checking the ignition timing recently using the measurement in mm BTDC method and failing to get the 7.8mm position I needed, thought, I have 7.0mm, How far out is that?
