1960 Dommie Speedo.
Hi,can anyonetell me whatthe correct speedo is for a 1960 Dommie 99.Chronometric and 0-120 mph I guess,any other information would be greatly appreciated.
Thanks Keith
Thanks Keith
Help needed to solve insurance problem
I have built (nearly)my Commando in the flat where i live!!!
Problem being, to put wheels etc on to start it up I will have to get it into the garage.
hi,my 1953 es2 has decided it will only get 4th gear if i tap lever gentlyUP, first and then maybe it will go in with a prod down.Sometimes i can get 4th if i leave it in 3rd and prod away after a short time till i get resistance,bit like lucky di
I have just got a Wassell Power Box as part of the upgrade to 3 phase - does anyone know where it would be best to mount it it? "Not in an enclosed space" says the litaerature, but I want to keep the wiring as short as posiible really.
Hi - I am just about finished restoring my 850 Commando and need some help with the side panels.
1. How is the Dzus clip fix to the battery side panel, is it pop riveted?
Well,have to say i didn`t expect such a fast response from so many people.I will follow up leads.
As i thought,a great club.
Hi there, I applied petseal to tank, it was clean and dry. The seal took quite a time to dry (several days).
Hi all,i have just bought 1953 ES2.My first classic for 10 years.Where can i get cables and a parts list from? i have looked on Ebay ,no luck.
Great club by the way,looking forward to meeting some of you when i get some cables,haha.
Hello All,
The twin carb's on my 54' Domi racer are causing a few problems. The slides close easily when the engine is not running. With the engine running, any light opening of the throttle causes them to stick open.
Just had some machine dating info returned from Chris. On the sheet my Model 20 came from the factory with a panel mount instrament and a dyna gearchange.
I am restoring a 1966 650SS dominator and I am looking for the orignal paint colour code for the petrol tank. the colour I am refering to is the same as the 650SS featured on the NOC website under model's ( dark graphite silver metallic).
did the featherbed bolt up framehave any weakness or was it just ease of production that caused the introduction of the all welded frame and what year did this occurr please.
Folks - I have a decision to make, and I would apoppreciate the views of anyone who has had similar experiences of their bike.
Can anyone advise if it is common practice machine down clutch pressure plates?
Thanks.
where can i find it on a navigator mine is powder coated over
thanks in advance dod
Hi all,
I'm building my first ES2 bike and need to set the valve lifter.I have looked through instruction/guidance books but can't find any information.
Does anyone have any guidance please?
Thanks, Rob
Can anyone throw light on the subject of Dommi fork oil seal holders ,I have just got a pair of new ones only to find the length of the threaded bit on them is10.27 mm and the ones I removed from my forks (7 3/8 short road holders) are 7.86mm so w
Hi all, not sure if this is in the correct place. I have a bitsa. Wideline with atlas engine. I was wondering if anyone knows what my front brake was from? Thanks Carl
I have a loud squeal from the front brake on my 1955 Dommi. 88, it is worst when applying the brake lightly, if applied hard it stops.
Hi, I am looking for 2 sets of contact breaker and 2 condensers for my 1961 Jubilee. Any contacts (!) that I can try before the club spares scheme is up and running in August?
hi , I am reading the letter concerning oil pumps, I W commented on the Suzuki TL 1000and states that the Suzuki engineers placed the pump before the cartridge filter , hence the damage to it .
I first posted the question in the Heavy Twins section but it's really a general Q - especially as I've just bought a 1961 Navigator de Luxe off eBay!
I've got a 1966 Atlas that was fitted with Boyer electronic ignition when I bought it, but it went wrong, so I refitted the magneto.
If you try to post by quoting a previous message, all of the content gets included in the quote section (red bar and greyed out)
Does anyone who maintains the site monitor this stuff?
I have heard say of a Norton parts supplier in the area of Southport/Ainsdale/Hillside. Does anyone have any experience of such a person and if so, do you have contact details?
Cheers chaps and chapesses.
Calling the owner of a 1961 Norton 500engine 94615/122.
Has anyone experience of fitting a 120 section or even a 130 section rear tyre to a mk3 commando ?
I realise I would need an 18" rim but curious to know what is the widest section tyre it"s possible to fit.
regards,
Some where inside this box of cyber space I spotted a chart that had info on gearbox numbers. I can't find it. Anyone know where it is, or similar info that outlines what the G102, G101 numbers indicate??
Bob
I've just fitted a single Mikuni VM34 to my 750 Commando, jetted IAW the american NOA notes. I could not get it to run properly at tickover.
