All Forum Posts
16H electrics
Hello I have had my 16h in the road for years and the electrics have always worked well, I have a modern AO services regulator fitted and the standard dynamo.
CS1 panel tank
Help Help!!!! I am just completing the restoration of a 1938 Norton CS1. I am having to have a panel type tank manufactured for the bike as it came with no tank. I desperatly need some photos of the underside of a panel type tank.
NOC events
I'm looking for some runs to do this year and was wondering what the NOC has to offer? I'm looking for predominantly riding rather than showing the bikes. Would the National Rally in Norfolk work for this?
Brake linings
After meny years away from Motor Cycles I have just started to re`build a norton twin, from the wheels up, I used to re`line the brake shoes myself, but now can only seem to find ready made bonded shoes, can you still buy brake linings & rivet
Commando wheel bearings
Hi Im restoring a 71 commando with a drum brake front and both the workshop and parts manual show a double row bearing in the drum with the same part number as the rear.The problem is mine never had one and I cant see where it would fit.Did Norton
More on oil pumps?
I have a number of spare Nortonoil pumps which I assume are all for heavy twins? but when you compare the hole ports some have only holes, some have slots and holes and some have a hole with long and short slots. what models are they for?
Dave Nourish retires
A friend of mine is having a crank overhauled by Dave an when he called to arrange to collect it he was told that at the end of this month Dave's machinery was been taken to the south of the country as someone had bought it all an that at the age
Slimline petrol tank leak
Hello,i am in the process of restoring a dominator i've owned since late 70's but has been garaged for around 15 years.never had problem with the tank leaking before so stupidly had tank resprayed without throughly checking it out other than clean
Frame number confusion
I recently bought a 1936 Norton ES2 in need of a complete restoration. According to the origional service book, and the later log book from 1961 the engine number is 70372, and the frame number is 70435.
Frame number query
I have a data sheet from the NOC showing various details of my Model 18. I have two numbers stamped on my frame one on the upper frame lug and one on the down tube tank lug.
Improving a Jubilee
When I turned 17, I was on the lookout for a 250, and spotted a Norton Jubilee in the classified of the Western Gazette, I didnt even know Norton did a 250 but fell in love with it and bought it (anything was better than the raleigh runabout it re
