Dommi main ign/light switch parts
Need your help again folks. Finding sourcing the 'little' parts is a real bind on rebuild completion.
My slimline has the correct Lucas PRS8 switch (the big multi connection one!)fitted but following the refurb I need the (stupid?) little rubber grommet that that fits inside the top of outer plastic switch, around the metal switch column and through which the 'key' fits.
Searching has thrown up plenty of complete switches but not parts. Do I have to replace the whole switch for a bit of rubber ?.
Any help appreciated.
regards John
regards John
well I have done some research for you but, it look like your going to have to replace the lot, as this rubber dose not seam to be available any where unless you may try a add in old bike mart .some one may have old stock you have to keep hunting , have fun yours anna j
The item you require costs £1.50, from Mike Boulton Motorcycles. Took less than 5 mins to find with Google search.
