I suspect my Tach is cream crackered, the instrument in question has functioned flawlessly since I bought the bike17 years ago. Whilst on a recent ride the neeedle suddenly started sticking & twitching all over the dial. After dismantling the drive end I found that the needle would stick after just twisting the drive cable a little anti clockwise, tapping the glass will free the neeedle. Does anybody have any idea if this is fixable - the instrument in question is the original Veglia?
Alternatively I could opt for a replacement electronic replica for a rather salty price. Does anybody have experience with fitting these e.g. into the mk III pod - I also notice a cable in my loom (mk III) which is labelled aselectronic tacho unused, can I utilese this (low user knowledge of electrickery).
Previously mike_sullivan w…
ThanksRoger, unfortunately…
ThanksRoger, unfortunately they state they will not repair motorcycle units. They have a linktoAE Pople, I'm pretty sure they won't touch Veglia instruments, but will give them a call tomorrow.
Cheers, Mike
The original rev-counter c…
The original rev-counter could be repaired and there are a few people who offer their services in the classic bike mags. If you think about it, because the speedo is taken from the rear wheel and the rev-counter is reading the engine speed which itself is related to the back wheel via the gearbox, all you are doing is seeing if your clutch is slipping.
The good thing about an electronic tacho is that it gets rid of the rev-counter cable and you could seal up another potential oil leak for good.
There is a book available on fixing your own speedo but it generally involves scrapping the bezel then finding a replacement.
Pople once took a wiggly l…
Pople once took a wiggly line Veglia from me as part payment for a Smiths repair so I think that he may do some work on them.
I had a similar problem wi…
I had a similar problem with the Veglia speedo on my Commando.
i managed to get the bezel off by carefully prising it with a screw driver, then I was able to reuse it after the repair, though I think the Smiths replacements that are easily available may fit.
my problem was grease and oil from the cable had got into to the speedo. If it gets onto the needle return spring, that stops the needle going back to the sop rest. If the grease gets into the magnet dish, that causes the instrument to massively over read .
So ist mainly just a job of cleaning the grease/oil out, then lightly re oiling with a light oil.
Clean any excess grease from the top 6 inches of the cable so it don't happen again, and don't over grease the cable.
There are sites on u tube and the net that cover generic instrument repairs.
Hi I've had an inner cabl…
Hi I've had an inner cable break near the clock end it all frayed and every time it tried to drive the rev counter it would have the effect of flicking the needle all over the place .Baz
Hi Mike, I have an electro…
Hi Mike,
I have an electronic tacho and speedo from Andover Norton, they fit perfectly, you will need to order the clock kits which are just a couple of male / female spacers.
Part numbers below (other suppliers are avaibale ....)
06-2277/E Speedo head, Green Globe, MPH or 06-2278/E ditto KPHor06-5638/E Speedo Head, NVT Arrow, MPH or 06-5645/E ditto KPH06-2279/E Tacho, Green Globe or 06-5643/E Tacho, NVT ArrowM5CLOCKKIT needed to mount the clocks in the long (850Type) Instrument Cups06-7904/E Speedo Cable/Sender to suit Rear Wheel Gearbox06-7316 Tacho Drive Blanking Plate (above) or alternatively 06-2874 Tacho Drive Blanking NutYou will find them about 1/3 way down the 'news' page:-http://www.andover-norton.co.uk/News.htmYou can get more details including wiring diarams fromhttp://puca.co/Can send pictures if required.RegardsTony
Hi Mike A couple of years…
Hi Mike
A couple of years ago, I took a Veglia down to Speedograph at Nottingham
http://www.speedograph-richfield.com/
but they were reticent to touch it, preferring Smiths - also £80 + vat then. Is your Veglia a green globe or NVT logo - I would assume the latter being a mk3? I have a number of spare Smith's instruments with NVT logo that are surplus to my requirements. Alan
Thanks all for input, I wi…
Thanks all for input, I will check that the upper part of the cable is still ok, need to replace fork oil anyway. Alan, I will contact you directly.
Miike
Hi Mike - I sent you a mes…
Hi Mike - I sent you a message on this board but I don't know how you pick them up - I also put my details on a PM to you on the AccessNorton site - if not, contact me via alsesh@aol.com Cheers Alan
Previously mike_sullivan wrote:
