For a 1958 Norton Dominator 99 Wideline Petrol tank, can anyone help describe the thread type and length of the screws that hold the round tank badges and knee pads? The knee pads are two screw type. I took some measurements and outside diameter of the tank badge screws are 3.55mm and the knee pad screws 6.30mm (excuse using metric!)
Previously anna jeannette…
Previously clive_stephenson wrote:For a 1958 Norton Dominator 99 Wideline Petrol tank, can anyone help describe the thread type and length of the screws that hold the round tank badges and knee pads? The knee pads are two screw type. I took some measurements and outside diameter of the tank badge screws are 3.55mm and the knee pad screws 6.30mm (excuse using metric!)
do you not mean BA3 there not metric, BA stans for British assocated Thread size. (0) to (9) in there size range,
BA threads are normally used for electrical fastenings. Switches, magnetos, ammeters etc.
3 BA is rarely used ....normally its 0 , 2 , 4 and 6BA.. I have some 10 BA screws and they are pretty small. They're ,not there, are an interesting thread , the dimensions almost metric
I think I may not have bee…
I think I may not have been clear in what I'm after. There are two sizes of screw on the petrol tank. One set of screws holds the tank badge, the other holds the knee rubbers. I need to know what size they are. For example 3BA, 2BA, etc. I know they won't be metric, I gave the outside diameter of the screws to provide an indication of their size.
On the Slimline tank, the…
On the Slimline tank, the badges are definitely held in place by 3BA screws. I gues that the Wideline badge has similar items. Colin is quite correct in that, generally, even number BA screws were the norm but in this case, Norton chose to be different. Most good Stainless suppliers have these in stock but you may have to cut to length.
Previously Colin Fairall w…
Small BA screws are used in the aircraft industry ,as well as electrical industry but there are BA screws on a Norton if you know where there fitted some are on the handle bar levers and switchs some are in magnetos too I do find BA and BSF and Whitworth a Cycle thread fasteners very intresting, thats what real makes a Bracebridge Street Norton uneek and fasanating machine . were as metric is boring, threads
our old Bracebridge Street Norton's have a sole all of there own , yours Anna j
I can now confirm the tank…
I can now confirm the tank badge screws are 3BA, Knee Pad screws are 1/4 UNF.I managed to source these at Lightning spares, (http://www.lightning-spares.co.uk). They're a BSA spares dealer, but I didn't hold that against them.Theyalso managed to supply an Amal Gasket set.
I realise the above postin…
I realise the above posting was written over a year ago but I don't agree. I have just checked the threads in a 1957-59 wideline tank that I'm about to use and the two screw holes that go behind the knee rubbers are 1/4x26tpi so they can not be UNF (which I believe is 28tpi).
Hope this stops someone using the wrong tap!
The two badge screw holes are indeed 3BA (34.8tpi).
Kind regards, Alan
Always good to have the re…
Always good to have the record set straight........
I have just come across th…
I have just come across this thread (pun intended) and I am somewhat bemused by the discussion. Does nobody ever simply look at some obvious documents, or know where information is readily accessible. If you simply go to the Norvil website, look up their price list (or look in the paper copy if you have one), and click on "Petrol Tanks"you will see the screws you require listed. Not only are they listed, with relevant dates for the tanks,but the size and thread forms are also contained in the description.
Agreed - lots of info on t…
Agreed - lots of info on the web, but it would be nice if the length of screws/bolts/studs were published, as well as just their diameter or type as in the case of BA items.
There is a very useful reference for all Triumph fasteners available (by old and new part numbers!) which is a Godsend if you have to make up a bit without a sample. I'm unaware of a Norton equivalent? There is one for Commando's I think, but for the early twins it can be a little challenging.
But the info is all out there. Somewhere.......
Previously bruce_kirby wro…
Previously bruce_kirby wrote:
â?But the info is all out there. Somewhere.......
Have a look here: http://stainlessbits.com/link12a.html
Not complete butâ?
Fritz
Previously fritz_wettstein…
Not complete butâ?
Fritz
Most useful - thanks Fritz!!
Bruce
The badge screws are not n…
The badge screws are not necessarily 3BA.
According to the Norvil site the tank badge screws on a 1955-1957 Dominator petol tank are 4BA and 3BA from 1957 on.
Although mine is a 1957 model, the badge screws are in fact 4BA, so maybe because the tanks appear to be identical an earlier tank is fitted to my machine.
In view of this I am again looking at the kneepads and the screw holes are at 4 1/8 inch centers and wonder whether the original were held in place with screws???.
Any ideas please.
Any ideas please.
As Anna says.....It sounds…
As Anna says.....It sounds that if the bracebridge street Nortons are a bit 'down at the heel' as they have "sole" . I hope the uppers are OK !
All my slimline tank badge…
All my slimline tank badges are 3BA but the round plastic badges on my 57 Pre F/bed Model 50 are held on with 4BA.
