All Forum Posts
Valve Oil Supply
I've replaced the valve guides, valves and springs on my 1936 Model 18 due to a blockage in the small bore copper pipe running from the pushrod cover to the valve guides.
Side stand
Hi all. I`m new to NOC .Could anyone tell me where to get a side stand for a 1963 navigator , I`m disabled and need a side stand to get on and off .
Frame number
I have an 850 Commando with what I thought were matching engine and frame numbers.  Certainly, the VIN plate on the headstock has a number which matches that on the engine.
made to fit
Hello I am now in the process of re-engineering an Aftermarket universal which  was on the bike when I got IT some years back, I will make this side stand fit correctly to My 1954 dominator model88  by cutting the lugs off the aftermarket side sta
made to fit
Hello I am now in the process of re-engineering an Aftermarket universal  side stand fit correctly to My 1954 dominator model88  by cutting the lugs off the aftermarket side stand   and making new lugs that fit the frame right and with a bit longe
New Rims?
The wheels on my 500T restoration look to be the originals - both Dunlops rims of the correct size and matching butted spokes. They certainly haven't been rebuilt in the 40 or so years I've known the bike anyway.
Page Numbers
Would it be possible to put the 'Page Numbers' at the top of each page as well as at the bottom, similar to the NOC shop pages.
Dommie headlight?
Can anyone identify the headlight shell that presently resides on my 56 Dommie 99. I get the feeling that it is not a Norton headlamp at all but I do not know how to research it. The rim is 7 1/2"  and it has a CIBI concave lens installed.
Winter lay up
I have loved the last couple of months since buying the Commando and despite a bit of rain have managed to ride it a fair bit (far more than i thought i would this late in year) but seems to be getting very very wet,and pretty cold at times so soo
Cracked fork leg
Hi. I was cleaning up a few more parts of my basket case 1960 Dommie 99 when I discovered that the left hand fork slider has a hairline crack across the underside of the spindle hole (first photo below).
Piston protrusion
With reference to my 1956 Dominator 99, could anyone please advise me as to whether the top of  a standard  piston should be level with the top of the barrel / spigots or should it protrude above the barrel top and if so by how much ?
Deluxe seat
Has anyone got a picture of the underside of a deluxe seat, I’m building a standard Navigator but want the tool tray under the seat and the quick removable seat, I used to have one but have forgotten how it worked!
