made to fit
Hello I am now in the process of re-engineering an Aftermarket universal  side stand fit correctly to My 1954 dominator model88  by cutting the lugs off the aftermarket side stand   and making new lugs that fit the frame right and with a bit longer to bolt to the bottom stud bar on the engine plates by removing the stud bar and replacing in with a 3/8ths new one that's a inch longer  to bolt on the inside part of the new type clamp I am making  so the side stand will move anywhere or slip around the frame tube, and it will be made so it does not catch the inner chaincase,  Today I was round to out Local  Scrapman to find a nice length of 1/12 inch wide flat bar and a nice long  length of 3/8ths round bar witch I found among the scrap with a lump of concrete on the end of it witch I will cut off with my Black and Decker  Angle Grinder with a cutting discs on witch will give me a nice  length of round bar witch after  wire brushing it clean on the lathe I can then mesrure it up for the side stand  for the bit that sticks out for your foot to push the side stand down when you need it,  the other end of this round bar will serve as the same on the centre stand  As the old one had broken off,  So now To weld a new one on with a better shape  back on so two birds with one stone  to do,  the flat bar is to make the new type clap brakets for the side stand  and I weld up the univeral part of this side stand so its at the right angle So it then fits right,  It will be a lot better then the New side stands you can buy From ANL  witch to me are to expensive,  this one I am reengineering as cost me  3 pound fithy for the steel from the scrapman  and 15 pounds for cutting discs  and welding  and some work  and a few mugs of tea and cookies  and a far better job that will work better  and last longer,  So ANL you can keep your expensive Norton sidestand mate ,,   Yours  Anna J
