All Forum Posts
Acceleration
Having recently purchased a 1973 Commando 850 Interstate,  I have been working through some issues and have finally got her running okay but she struggles above 5000RPM becoming very sluggish and jerky to accelerate.
LUCAS 1950s
In the 1950s Lucas changed from Negative Earth to Positive Earth with regard to motorcycle electrics WHY??
There is going to be lots of guesses to this-I can guess better than most, but I want the real answer if anyone might know??
Gear box oil seals
I've given up trying to get the cover oil tight, the square seals don’t work for me at previous owners have butched the seating groove, so this was my answer, I’ll let you know how it holds up!
1935 Es2 ignition timing.
I have recently replaced my timing chain, so obviously had to retime the ignition. I set it at 3/4 btdc as stated in the Frank's Manuel. It starts easily, although now it has to be a lot more retarded than before or I get kick-back.
Norton 19S Piston
About 40 years ago the owner of my 19S decided to over bore it to 85mm and fit a pre-war Triumph T90+40 piston, giving it a capacity of 641cc, a silly compression ratio of near 9:1 and a few other "go faster" mods equally out of character with its
Commando clutch
Hello all,
New NOC member here and new to the forums too.
I've bought a 1974 850 Mk2A a couple of weeks ago and have been steadily working my way through the (thankfully minor so far) list of snags.
16h top nut spanner
hi i seem to have 2 different cranked top nut spanners, one fits my bike 7/16w, the other has raised letters (gearbox top nut) & is 9 1/16w  , can anyone explain are they both norton ive sent an atatchment, thanks pete
Barrel height
Can anybody please confirm the original height of a 1956 Dominator 99 cylinder barrel ? My barrel has had the spigots removed and the  machined top boss height is minimal and washes out to part of the right hand side top fin.
Hagon Shocks
I am going to replace the rear shocks on my 850 MK1 Commando, rather as a matter of course, not because I know the old ones are definitely unserviceable.
7/8" fulcrum
Does anyone know who might sell a 7/8" fulcrum clutch lever for a 7/8th handle bar?
My Electra currently has a 1 1/8" fulcrum and is a bit tough to handle for any length of time.
