dominator engine square four frame
has anyone ever put this combination together
Bikes been running well, left it for a month with the battery on charge, upon starting the engine is running hot and lean (popping and plugs white)
It is with great sadness that I have to inform you all, that the amazing frame, bike builder, and TT rider Colin Seeley passed away in a Woolwich Hospital, today. We so sadly diminished by such a sad loss.
I have reason to believe that my vertical shaft has been shortened but can't find any spec on the original length. Anyone got one available to measure? Any help greatly appreciated.
Thanks,
Can any member advise what these are worth now? I have tank and seat and want to sell!
Hi.
Ive been trying to source a rear brake arm lever and spring for 1947 International.
A2/469 S7
A2/470 S8
I’m currently building up a 1954/5 prefeatherbed swinging arm ES2. I have fitted a laydown box but cannot get enough clearance behind the clutch for the chaincase.
Hi
I have searched the NOCshop and I can not find an ignition points cover can anyone please point me in the right direction.
Steve
Hi, first time Ive had my commando apart, and a very long time since Ive built a four stroke engine so Im a bit green.
Hi.
I’m fighting with my 1960 Dommie 99 basket case. It’s looking more and more like I’ve bought a collection of various bike bits rather than parts that have some kind of relationship to one another.
Hello Members Well I do believe is time for White hot designs to come up with a good spell checker of its own, So as you log on to this site it this automatically triggered as you are writing and I helping you to write as well so and autosave
What would the color code be for the blue RAC Norton sidecar combinations like the one in the picture attached? Thanks, Bennie
My 1973 750 carb is an Amal R 932/26. Does this sound right for a single carb set up? Ta.
Took off oil tank today, crimped the chain oiler take off and brazed it up. It was more of a nuisance than anything else.
Anyone else do away with theirs?
750 commando.
As I am close to completing the rebuild of the top end of my 1956 Dominator 99 engine , I need to replace the damaged pushrods and I have carefully checked the rocker geometry using a home made adjustable pushrod.
Can anyone advise as to where I can find replacements for these rubber grommets
Hi
can anyone tell me the correct size oil seal that sits inside the timing cover I’ve bought one from a reputable dealer but it seems to large on outer dia
the engine is 1958 99
cheers for any help
pete
I have a 750 Roadster, 1973, with a drum brake which doesn't inspire confidence. Is there a disc brake conversion for this bike, and is it an easy swap? Ta.
As a responsible NOC member I have taken the time to read the Updated Message Forum Policy and wonder if the chunk copied below could do will a little clarification.
Hey everyone hope we are all well.
Just starting to look into getting my first ww2 bike with the aim of using it regularly.
Currently ride the Norton 650ss as a daily.
I am rebuilding a ES2 - Roadholder forks.
I have found that the bike came with long Roadholder forks.
The Featherbed takes the short forks.
Is it possible to convert the long to the short?
Hi all - doing a little advance planning for my someday 1956 Dominator 99. The cylinders have several large pieces of finning broken off and missing. I missed a set on eBay that came up here in the USA.
The booking system for both the NOC National Rally - Headless Drummer Rally at Herstmonceux, and the NOC Internatio
I’ve had a few garage hours this afternoon and did some work on the nav I’m building from a box of bits. This mostly involved searching out the best front frame member to use.
Just a BIG thank you to the Shop “elves” this Christmas!
