Hi, should the two front sleeve nuts and the rear nut on a 750 cylinder head have washers?
Thanks.
Hi looking for a battery for my Dads Norton 650 1963. I've already ordered a battery but its to big.
any help would be great?
Hi
I’m rebuilding a 1958 dominator the engine’s out and on a bench head off so nice and easy to get at everything
Hi
on dismantling a 1958 dominator 99 cylinder head I’ve found some fibre washers under the spring bottom cups that do not show on the drawing I have just wondering if they should be there or has some one added to tension springs
Just been in receipt of an email from a Neil Wilson quoting my ad (from this forum) for hub trims.
Anyone have a complete speedo drive for a 1934 16H they fancy selling...cannot find one anywhere. Oh and a Smiths speedo to suit that year??
A number of members are reporting difficulties logging into the site - as reported on Accessnorton
the messages is “can’t find server”, both overseas and UK based members
john
Has anyone got any suggestions on how to extract the Drive side Camshaft bush from my MK3 crankcase, the timing side bushes came out easily with some gentle heat. This bush is Blind so its a bit more tricky, any ideas ?
hi can anyone tell me the length of wd 16h norton handlebars thanks pete
I am wondering what the general opinion is regarding Kegler Clamps. I have found that these seem to be available in the USA but cannot see a supplier in the UK. Are they not deemed to be an acceptable modification?
Does anyone happen to know the approx. weight of a 650 ss piston?
Hi, would anyone be able to recommend a workshop in South West London area that could help me with a mk2a 850?
Hello guys. I am after an image of a wiring diagram for a hand gear change 1934 16h, quite rare l am told? It has all guages and switches on the tank.
Hi
I'm after a bit of advice, I'm stripping a 650ss engine and so far most bolts/nuts have been a nightmare to remove (I think threads have been subject to Loctite or something similar)
First..a big Thank You to the Roadholder team (editor and contributors) for the magazine and especially for the technical articles recently.
Hello,
Its a 1950 Model 7 plunger and restoration is coming along slowly and I purchased as a basket case so unsure of some fittings process. Can't find a manual that shows details for fitting for rear mud guard, oil tank etc. etc
Hello
The tank of my 1957 Dominator 99 need new paint. Roy Bacon "Norton Twins" says petrol tank in gray with chrome platetet panels. I have the panels, the rest of the bike ist black.
Does anyone have any tips for fitting of isolastic rubber gaiters (I.e. how to persuade them into place without damaging anything)?
Had a half hearted attempt at it last night and thought I could benefit from asking!
Hello, NOCs I was wondering how many Norton16h war bikes went to North Africa In ww2 AS that were My Uncle John Served In the desert of North Africa in Squids of 15 or so all on Norton 16h.s fitted with light machine guns and a hand grenad
I recently had my 376 Monoblocs refurbed, and am now in the process of setting up the carbs. Can anyone confirm the basic settings to start from.
Hi I am new to Norton and have just acquired a 1949 model 18 rigid fitted with a 1958 ES2 motor. At some time this engine was removed and various modifications made to the frame to accommodate a different engine.
Hello have somebody foto of origin holder for tachometer-rev counter on model where was speedo in light and tacho was separateli?
thanks
Tomas
