All Forum Posts
Con rods
Hi All,
Would someone be able to say which one I should use in my rebuild as I seem to remember one type is considered weak and shouldn't be used.
Many thanks jim
Percy Tait
Hi all, I've just read on the TR3OC website that Percy Tait has died aged 90. A sad loss, but what a life!
branch site login
Can we have an explanation please?  I am logged in to the main site as an NOC member (or I would not be able to write this).  But when I follow the link to my local branch site, I find I have to login again - but my login name is invalid (because
Push rods
I am midway into rebuilding the top end of my 1956 Dominator 99 and on checking the push rods I have found that one of the exhaust push rods is badly bent and the other three are scored. They are tubular aluminium with steel ends.
helicoil insert
The front centre barrel base stud is stripped in the crankcase on my 73 750 Commando. A previous owner had carried out a repair/disguise. I guess it'll need helicoiled, but I've had no experience of helicoiling.
Roadster seat rebuild
A couple of years ago the seat on my 1973 Roadster broke in two. The seat base had rotted most of the way across between the mounting points such that the rear of the seat was only restrained by the foam!
500T Restoration
Just joined the club and my first post. I'm about to embark on a rebuild/restoration on a 1952 500T and thought it best to ask a few questions before I get started.
Valve spring length
Hi
im replacing the valve springs on a 1958 99 and the Hayes manual says the length should be
outer 1.700in
inner 1.531 in
which the ones I’ve taken off are just slightly shorter(reason for changing)
63/64 forks
I’m trying to resuscitate a set of late forks, the ones with the square bottom, does anyone know how the springs come out of the slider, I’ve undone everything but no success so far!
Dan
Frame repairs
Looking for somewhere to do a frame repair job in the Northwest. It's a brazed lug type frame.
Will require old (suspect) repair stripping, and possibly a new front down-tube fitting.
