All Forum Posts
Magneto
Someone please tell me how I can remove the slip ring from the contact breaker assembly. I have tried levering, I have tried freezing with a frozen broccoli to contract it away from the magneto body.and left it to soak in WD40.
side stand
Here I am again!
please can any one help.  My mk3  Commando had no side stand when I bought her. I bought a new side stand kit from AN, however, I cannot see where the spring should attach to the frame/engine .
End of term report.
I have  been using Yamalube 10/40 fully synthetic in my 99  for  3 years,  now on my 3rd  winter  oil change , Oil was free so my parsimonous  attitude put me up for it !.  I had been using a variety of oils before all with a low detergent  spec a
Mk2A bottom yoke
I'd appreciate some advice - once I have removed the steering stem nut and tab washer should the bottom yoke just tap down and off. I'm wanting to replace the headlight bracket (shroud) bottom 'O' rings.
Thanks   Roger
crankcase ID
On the back face of the drive side crankcase, there is a number - 99C 3724. Delved into the forums and it seems to be a factory production number.
Clutch question
I have noticed clutch back plates for sale and want to know the difference between plain and the ones with friction material on them, and also can you mix n match them.
Battery low
Hi new to the forum so hello to everyone!!
Recently purchased an 1975 mk111 850 as my Triumph days of kicking are over due to a bad ankle. Bike has been standing for a few years and the owner was deceased.
Battery charging
I have a 750 Commando with an Alton starter and an A reg1 regulator rectifier. When I restored the bike two years ago I retained the assimilater which controls the charge warning light.
What Frame is this?
I have a garden gate international frame which in an earlier life was cut up to make a TQ (Three Quarter) midget speedway car in Australia. The only marking I can find on the frame are:-
Brake shoe slippers
I have managed to amass a collection of brake shoes  7" sls   8" sls  and   8" TLS .  I can even tell which is which at a glance   (thats a bit sad !).  I am curious as to why some new shoes come with steel slippers and some do not .  In the past
