All Forum Posts
Gearbox & Engine DVD’s
Regarding the DVD's available at the NOC online shop relating to gearbox strip down / rebuilds and engine strip down / rebuilds: I wonder do they include the Mk3 Commando?
Has anyone with a Mk3 bought these products?
mod19 piston
hi i purchased a new 82mm  genuine norton piston,for my 1954 mod19 to discover it is heavier than the original, more robust, with a slightly shorter skirt,does anyone know why it is heavier, thanks pete
Atlas Gear
Would there be a replacement gear on the market for the mechanical auto-advance when converting to electronic ignition?
Exhaust Roses
Having purchased a pair of bright shiny exhaust roses to go with my bright shiny pipes, I set about instalation but even after wringing up the roses the joint was not tight, i.e. the pipe was not gripped.
Single Carburettor
I am sure that this is a topic that has been discussed many times before but here goes.  I am planning to fit a single Mikuni carb to my 850 engine which is currently being rebuilt by Norman White.  There does seem to be 2 schools of thought on wh
Air filter lessons
Last year I added a "Ramair" foam sock filter over the Inter bell mouth. Seemed innocuous enough and on the road I didn't notice any adverse effect so, although it's ugly, it should help keep the engine wear rate down.
N15CS Numbers
      Can anyone please tell what year these numbers from a N15CS hybrid are from and if so do they look correct:
Frame and Engine have matching numbers: 120823
Gearbox is NA15690G
Speedo cable
A while back, I bought a new speedo cable, made to measure by Venhill.  I wanted a slightly longer cable than the old one (it died when I tried to remove the inner cable to lube it, and .... )
Magneto
Someone please tell me how I can remove the slip ring from the contact breaker assembly. I have tried levering, I have tried freezing with a frozen broccoli to contract it away from the magneto body.and left it to soak in WD40.
