Tank badge Colour
Hi all
Im in the final stages of my Slimline Dominator restoration. She is the Green and Dove Grey.
Hi all
Request of advice in adding a sidecar to a P-11A
Have new steel tank and fibreglass side panels and want to refinish them in the original light blue metalflake colour for my 69 S code (as per example)
I took my wife to the museum on Monday 2nd Jan as a special treat! (No - REALLY!) She loved it as always and, after our tour, enjoyed reminiscing with the staff about her Dad 's bikes in the 1950s.
This maybe a cunning plan or just plain wrong, but here goes. I had my electronic ignition blow up on me this last summer and this led to an awful lot setting the white dots through the rotor in the old points position, checking for 28 B.T.D.C
There was an anomaly with the 2021 Club Accounts which needed clarifying. Hence the enclosed should sort this.
AGM 2022 Accounts
Hello all - I've just bought a '63 650 SS with several 'rider mods' already in place (including a 12 volt conversion - no Mag, an as yet unidentified electronic ignition and a RGM belt drive primary ) Apart from this the electrics are unknown to m
I'm restoring a 1973 850 Interstate.
The leads down to the Zener diode have melted and I'm planning to ft a Swiss 790 (Royal Enfiel) regulator rectifier in place of the original Zener diode and rectifier set-up.
Background: My 1967 650ss was produced in April of 1966 and subsequently imported to Berliner in US. I bought it from the late Morrie Gauger in 1986.
Hi I’ve just joined the Norton owners club as I’ve bought this Jubilee and I was hoping for some help to get it running and eventually looking a bit tidier, It’s got good compression so not seized up.
I noticed a few items I purchased are listed as copper/asbestos I’m presuming that they are not asbestos, but a modern replacement?
I have bought an Atlas engine ( I think ) with a head that I can't identify.
It has 32mm inlet tracks. with !.5" valves
Rocker oil feed is on the side of the head.
Hello all, new to the site, but with a long passionate history for Nortons, along with other old bikes.
I have a Norton 650SS with Dunstall exhaust fitted
I have all the parts to fit forward foot rests connected through the Primary chain case cover
Hi all, advice please. I have not ridden my 1960 Dominator 99 for a couple of months but have started her regularly. I was going for a ride today but the clutch would not work.
Does anyone recognise the fork conversion on my 850 Mk2A commando.
The fork top nuts have a removable centre, which exposes what appears to be an adjustment screw - presumeably for damping.
I'm confused about how to set the auto advance unit on my Electra project. I would assume it has to be positioned correctly on the camshaft, but I can find no information on how to set it up. Anyone able to help?
Thank,
I have recently joined the club owning two Nortons, a 1973 Commando and a 2019 V4SS.
Hello, I am interested to know what factory colours where used on the mk3 commando's
cheers
hello,
all the best for 2023
Barry
please have someone instructions for this kit i cant find it
Tomas
https://www.rgmnorton.co.uk/buy/aftermarket-lockheed-type-alloy-caliper-conversion-kit-wassell_4674.htm
Hi guys
I'm just stripping an 850 mk3 motor for rebuild. I have found it is fitted with these pistons. They are 79mm and forged. There are no markings at all.
last call for anyone selling steel roadster tank and panels to fit mk3
Now got a tank and R/H panel, still looking for the L/H mk3 panel in steel
cheers
Hi All, I have a 1975 Commando MK3 with a primary drive belt conversion. The current belt is a Medway Power Transmission type HTD 880-8M-50 and shows signs of a wear on one edge.
Father Christmas brought me the dvd of John Hudson rebuilding the heavy weight engines. In the dvd John used oil on components while rebuilding the engine then he primed the engine with oil. However.
Hi all,
I’ve been restoring a Jubilee that last ran in about 1970. Today I got to the point of seeing if the engine would start, it didn’t.
Hi again everyone I hope you have all had a good xmas and have and a happy new year, I have what is almost definitely a repro seat which fits surprisingly well and looks as it should, but it does not have a fitting hole threaded or otherwise for t
