Guidance on registering a reconstructed classic?
Hi, If I'm posting this in the wrong place please remove/relocate/let me know where I should go.
I have just had a rebore on my 99 barrels and about to fit a new pair of old stock + 020' Hep 13325 Pistons.
I’ve bought these Doherty levers for my jubilee but the holes aren’t big enough for the original bolts I’ve got, Is it acceptable to drill them out or have I bought the wrong ones?
Hi All, I am looking for this bike. 367UMH
photo was taken around 1969.
DVLA says last v5 issued in 2011 so I am hoping someone here has it?
thanks
Could anyone tell me where to purchase front brakes shoes? I’ve looked them up on Andover Norton under the pre-featherbed tab and it shows the front brake shoes 7” as rear brake shoes…is this correct?
Thanks much.
Nate.
Idly browsing the MCN I’d bought for the Excel Bike Show guide as I ate my lunch today, I read an article on hydrogen fuel cells and their possible application to bikes.
Hi
After a lot of work I have now sealed my cylinder head and stopped the dreaded smoking from the valve guides.
Hi all
i recently bought a 1936 Norton 16h an wondered if anyone could point me in the right direction for an engine rebuild please ,London areas if possible but not essential.
thanks
john
I recently noticed that the tank oil filter on my Dominator was broken, so ordered a new one from RGM, part E2/398. It would not fit. After a bit of faffing around, I discovered the problem was that the new mesh filter is too long for a featherb
All,
I have a 1956 ES2 with the round plastic tank badges.
I bought some new a few years ago and both have cracked in different places.
Gentlemen-
What vintage of Model 16H crankcases are the stoutest? I would imagine the units from the WD era would qualify for obvious reasons, but I'm not certain.
Any ideas?
Thanks!
-Robert
I'm currently restoring a 1960 99 Slimline Dominator & have found a rear mudguard with rear light assembly & bars on ebay but can't be sure whether it will fit.
I recently pitched a 1952 500T at auction here in the USA.
per paperwork, it is registered as F3T21054. I cannot find this number anywhere on the bike, where should I be looking?
Hello,
I have a NOS Manx Norton tank for sale, never had a drop of petrol in it.
comes with original label when Ray Hill purchased it.
correct with baffles and original paint.
POA thank you
Yesterday I collected a trailer load of bits that are purportedly a dismantled Norton 650SS. Today I've started to sort through what I bought and look at numbers.
Hi, does anyone know the size of the belt, that this kit came with? Thinking of refitting it but have lost the original belt.
Hi all, looking for some advice please. My brother in law and I are restoring a 16h that he purchased some 35 yrs ago but never got round to doing anything with.
Hi Members, Regarding my previous post on Atlas flywheel with all of the drillings. I ended up buying a 650ss flywheel with a choice of 3 off the UK website with worn webs of 40thou and now start again, using my 650ss webs which have been machine
These questions pertain to an 65 Atlas converted to electronic ignition.
I retorqued all the head and cylinder nuts on my 1972 750 commando today to hopefully eliminate an oil leak problem (separate thread…I think I’ve found the problem) but I was unable to find any tool that would fit onto the rear cylinder head nut.
Having read some of the previous threads concerning Manxman 650s, I hardly dare ask but...
Hi All,
Noticed this hairline crack on the pinch-bolt fork slider on my Dommie 88.
Has anyone had any success in repairing this sort of damage - or will I have to fork (sorry) out for a new one??
Thanks,
Aston
How many different tank capacities were fitted to the slimline twins.. I make it 3.
Folks,
I replace the non original carburetor with AMAL 76AK/1AT in my Dommie.
The bore is 1" but the alloy manifold (carburetor to head) is 1" 1/8.
It's normal that manifold is larger than carburetor diameter? or what?
Hi, any recommendations for engine oil for a 74' 850 please? Thank you for a good spread of advice;I think I'll try the 20/50 GTX.
I have done just under 200 miles of gentle-ish shakedown running on my newly restored 99 engined 650 SS bicycle and have so far been underwhelmed by the SLS brakes.
