Can't select neutral when hot
Hello again
If you're thinking "Don't know much do you...", you would be right.
Hello again
I will be travelling to Portsmouth for the ferry crossing on the 7th July, as I will be leaving from west Cornwall I will be driving up with the bike on a trailer, The parking rates for a car and trailer at the terminal are rather extortionate.
Hi I am thinking of replacing the clutch on my 1950 16H. It is just restored after lying for some 30 odd years.
Also I may change the carb to a new one, Has anyone any contacts for these items and what is the correct carb for my 16H
can anyone advise whether you fit heat insulating washers under the spring seats when fitting a 2s/combat camshaft in a 750 engine. regards alan
Anyone wanting just a tad more detail on Heavy Twin cylinder heads may like.http://atlanticgreen.com/nhth.htm.
My 1960 model 99 Dominator enginehas been totally rebuilt. It seems to have intermittent oil starvation to the rocker box.The oil seems to be going straight back to the tank instead of up the rocker box feed. Can anyone help please?
Has anyone out there got a Parts List for around 1961? Could you please let me know the part number for the bottom yoke for a 1961 Model 50. I guess it mightbe the same for all Slimline Featherbeds.
Can someone please let me know the correct tyre pressures for a 1960 Jubile Deluxe.
Adrian
Hello all,
I'm delighted tohavejust bought anotherMkIIA ('74 from the US), so as a new member (actually rejoining after many years with BMW's), have a couple of questionsregarding Commando (850cc) exhausts :
1946 Model 18. DU142 headlight rim retaining clip required. Can anyone help please?
Even a decent photo of the clip so that I know what I am looking for would be much appreciated.
Richard Norton
Fife.
I have stripped and rebuilt the primary side of my liquid cooled rotary engine. Now I need to adjust the clutch. Does anyone have a suggestion of how I can best do this.
HI, can anyone help with the quantity and grade of fork oil for an 1949 ES2 500.Thanks Gordon
Hello all,
I have a '68 Atlas and I intend on replacing the rear sprocket. The current one has 42 teeth and the numbers M12 & 030019 inside. I have a 5/8 x 3/8 bolt up ('64 on part no. 030052) but it doesn't fit.
Hello
Below is the reply i got from Maxton when enquiring about suspension modifications. Has anyone tried this and what are the results? this is not a cheap option.
thanks
oil coming from breather on tick over is this normal or can any thing be done to stop gratefull for any help yhanks
Hi
The 99 I have just bought had an oil soaked clutch.There doesn't seem to be any leakage from the crankshaft seal, so I'm hoping the chaincase just had too much oil. I'm fitting a clutch operating rod seal just in case.
Hi Chaps - for some time I've been following the progress of the Brit-Bikes (USA) Commando electric starter conversion - it looks as though they are ready to start marketing it but it seemsvery expensive and complex to fit.
The bike is a standard1960/61 Domi 99, using Roy Bacon twinrestoration book as a referance it was always my plan to usehis decription to finish my bike in ie.
I have a 1961 Dominator 99. Engine was rebuilt a few years ago with new valves, guides, valve springs, all from Mick Hemmings. Bottom end was also done.
Hello I'm Steve - I've got a 750 Mk4 Commando that to be honest I've never had running properly. It runs on one cylinder, sputters on the other, ocassionally fires on both.
I'm rebuilding my 1972 750 Commando in the basement, don't have a shed or garage.
There's been a lot of discussion on getting 8 thou clearance between the rotor and stator.
I have recently taken the top end of my 1949 ES2 apart for a de coke and think that I may need a new piston or at least new rings.
I am about to start the restoration of a 1938 ES2, can anyone recommend a supplier (if any exist) of parts for older Nortons? I am new to bikes of this age so welcome any advice comments!
Nigel
I want to change the magneto to electronic ignition on my 1955 dominator 88 to make it more reliable as it is harder to start when hot and i believe this might help , can anyone advise on the best system and a rough idea of cost ,
Annoying little problem with my '72 Roadster- my kickstart rubber keeps sliding off. Hardly the most complex tech issue.
Is it possible to incorporate a facility to edit and/or cancel one's postings as the fingers-moving-faster-than-the-brain character flaw from which I suffer often renders these sort of tweaks necessary?
Hi , Anyone know the exact colour and where to get the paint for my 1955 it looks like a gun metal metallic and silver , i have a few blemishes that need doing chain case etc .
Thanks . Bob
Can i put a twin leading shoe on this bike ? will it fit as standard or will there be a lot of trouble ? also where can i get one ? any help would be most helpful . Thanks Bob .
A friend of mine had to buy a pair of new commando crankcases after a major letting go of a con rod bolt. After 4,000 miles he stripped the rebuilt engine to investigate poor compression.
