Hydraulic clutch adjustment
I have stripped and rebuilt the primary side of my liquid cooled rotary engine. Now I need to adjust the clutch. Does anyone have a suggestion of how I can best do this. The procedure in the Commander is for a cable operatedclutch that doesn't work on my bike as it has a hydraulic clutch conversion.
With thanks to Richard Negus I have now been able to adjust the clutch on the rotator.
For anyone who has the same problem:
1) Remover cover and push the slave cylinder back as far as it will go.
2) Slacken off the lock nut.
3) Adjust the actuating rod using a screw driver so that it can just be rotated by hand.
4) Tighten lock nut.
5) Operate clutch a couple of times and recheck adjustment.
6) Replace cover.
Should the system be bled of any possible air before undertaking the adjustments?
