Hello to all NOCers - We now have a web forum for East Yorkshire Branch. To enter type in the left hand top address bar http://grou.ps/noc and that will get you on to our website -
I was very sad to read thenewsthat Keith had passed away, I met him at the Classic NEC. He was a very nice man and a genuine Norton enthusiast just like me. It's very sad knowing I'll never get to shake his hand again. Anna J Dixon
The 1960 basket case DomiI have has 7" yokes, but it has fork sliders from 7 3/8 wide fork, I was going to have thammachined on the bottom and turn them in to 7" sliders by removing 3/16 of the inside of each leg.
looking at the top of the metal dustbin which is the rear of my navigator deluxe, there are four blanked off holes in a position that may be associated with a rear carrier of some description being attached, was there one available?
Hi to All you Nocers if You want Millers Oil I can Serply it SAE 30 40 50 & 20/50 classic
at 18 pounds a gallon contact me on annajeannette@btinternet.com Allso Gear Oil EP80/90
Hi all - I have Commando Mk2A converted to 920cc - it has been fitted with a single 36mm Amal Mk2 Concentric for a long time and has always been a good cold-starter but a pig to start when warm or hot - the only way to get it to start shortly afte
I read somewhere recently, and now I cant find it for the life of me, about someone wishing to fit panniers to a Commando.
Hi FolksWhich are the best shocks to fit a Norton Dominator?I have fitted a Commando engine to it and I ride quite hard the budgetauto jumble shocks are notup to the job any more.CheersKierranForest of Dean UK
Just currently fully restoring a Combat engined roadster and need some advice on options. The engine is in good condition and Superblends had already been fitted - using the original ss cam and standard compression ratio.
Does anyone know if 1960 Domi 99 had a transfer on rear mudguard
I have two wideline tanks, one (Tank A) which has the embedded nuts for the chrome sidepanels and one (Tank B) which has only embedded nuts for the badge and should be chromed and painted.
Has anybody got any ideas about converting the Commando to negative earth? I have recently bought a HID headlight and the wiring for it is obviously designed for -ve earth.
I've just received the latest issue of Roadholder and must say how impressed I am with the content. Added to that, the new web site is a long-awaited bonus. Well done, all !
I'm in the final stages of my 1939 WD16H rebuild.
Hello,does anyone know an equivalent to Flamboyant Burgundy as used on 1966 Jubilee?Cheers ,Mick Trown
As part of my ongoing Commando restoration I am now tackling the engine, which needs alot of workdoing to it. One job I have been trying to resolve is the cylinder head which is a complete mess.
I amplanning to renew some seals in my 73 gearbox this weekend. I'm taking thegearbox out to do swinging arm/ cradle stuff. I think I have a leak form the sleeve gear bearing seal and I know I have a leak from spindle/quadrant.
Is it preferable to use a hosting service such as Photobucket ? If so, then it would be useful to have a preview or save facility in order to leave the page and load a second image.
Hi all,
My suggestion would be that casual observers to the site can't see members names shown on postings, you need to be signed in to see these.
James
Can anyone please advise what the available paint schemes were for the above machine or was it just Polychromatic Blue.
Thanks.
Chatting to an alledged expert dealer earlier last year, I asked why he insisted that owners of newly built Commandos must use SAE40 grade engine oil, else the dealers warranty would be invalid.
I have just put this message on here to get the forum started.
The filming for the new NOC technical DVD on Norton Singles engine disassembly and reassembly has been completed and the first edit is under evaluation.
SRF 62 L was a black Interstate model with the infamous 'combat' engine. (Yes, it blew up after 5,000 miles!).
Well this is a pleasure. Well done to all concerned.
Welcome to the NOC Board - A fully featured Message Board for NOC Members. Logged-in members will be able to start and respond to threads. Administrators will be able to moderate Boards and control activity.
