All Forum Posts
Commando timing RPM
Hi folks
I am trying to set the timing of my 74 Roadster.
it is fitted with a Boyer Bransden mk3 unit.
i have set it static at 31deg BTDC but not sure what RPM to run it at for the strobe.
Swinging arm
I have a 1972 commando and I have an issue on the swinging arm.
The loop that is welded towards the front that you then bold the front of the chain guard to has broken away. The break is a clean one.
Brituro silencer
I've just bought a pair of silencers from the club ( brituro cigar type) does anyone know what the thread is in the captive mounting nuts, I kind of expected that it would come with 4 bolts but it didn't!
Dan
Exhaust Port Repair
My 1956 19S (Alfin head) has stripped the threads in the exhaust port. Has anyone had this type of repair done recently, and if so who did you use? Did they do a good job?
AMAL 375 jet block
Hi, the AMAL 375 seems to have been used on a lot of bikes, however the final digits - in my case 375/48 for the Navigator provide the configuration info - unless I am mistaken. This is with respect to the jetting and bore sizes etc.
Roadriders
hi, I was going to change my tyres to roadrider's 100/100 front and rear but can't seem to locate them. I can only seem to locate 100/90's, have they stopped making the 100/100's?.
is there any real difference anyway?.
Upcoming Events
I can't believe that the upcoming event seen right and happening in Witney has not received numerous double entendres???!!!
Foreign bodies
I have been given a 1957 99 engine, and frame. Not knowing why it was put out of service I thought I would have a quick look in the chain case where I found these two bits of metal floating around.
Vibration
Hello all. Ive just re built my 1st Norton Commando 850 MK2a. I road tested it the other day and now wonder if the vibration Im getting through the footrests, seat and handle bar grips is normal for these things?
Cheers. Steve
