All Forum Posts
She lives again,
After three years of sitting in my garage I had a couple of days to see if I could get the old girl running, she's not a restoration, I'm just trying to put together a cheap buy on eBay into (a box of bits) into a usable classic.
Members Locations.
I'm pretty sure many of us would like to be aware of other fellow members who might be living nearby after all we are in the same club and we are all a friendly bunch aren't we?Smile
Leaking forks
I have an irritating leak of fork oil from my long Roadholders. It's coming from the bottom bolt that threads into the pressure tube. I can't fit a fibre washer, the wheel spindle will foul on the bolt head.
ES2 PVS 643
Looking for my old bike,if the current owner who i beileve lives in the Oxford area would like to contact me i have the bikes very interesting history including its original number. Regards Alan
Z plates
Hi, can any member tell me the difference between the left hand z plate for a 1971 commando (06-0944) and the one fitted to a mk3 (06-5961) many thanks.
John.
RM21 Wiring
My 650SS has a RM21 12v 2 wire alternator, the wires coloured white with green stripe and green with yellow stripe. A modern rectifier is fitted, with 2 yellow wires in and a black and a red wire out.
Spraying
Whats the best way to spray a Jubilee frame. Can it be sprayed bolted up or is it best to dismantle and spray parts individually.
Can anyone recommend a paint spray in the Manchester area
John.
CS Type Clutch
Can anyone help in knowing the trick of removing the roller race and back plate on a single spring Sturmey CS single spring clutch. My bearing has worn which means the basket float's about and makes a lot of noise.
Lucas spares
As I am in Melbourne, Oz and tend to buy spares from the U.K., I have just received a new wiring harness ordered for my 1953 Model 7. It is a new harness, correct with cloth braiding and in a new Lucas box.
