All Forum Posts
To Boot!
can anyone recommend a decent quality make of classic motorcycle boots?
6v LED headlights?
I have three 6v English bikes, including my ES2 and I like riding all of them. In order to ride to work in the winter months I have to ride at night and while the tail lights are mostly adequate the headlights leave much to be desired.
Half time spindle
Hello, probably not important but, where would one position the hole on the intermediate spindle? top middle or bottom, too paraphrase the vernacular, I dont want any hot spots through poor oil flow, what is a hot spot?
Poor rear light
The early Commando rear light emits very little light and even with a led light board upgrade, it might consume less power but still isn't very bright.
1931 20 rocker arm
Are the rocker arms on a 31 model 20 set on a taper shaft only or with a key?
Parts book shows what appears to be a taper rocker arm shaft with a key . The hand book gives no information on removal.
Jubilee battery strap
Hi all,
can anyone send in a photo of the Jubilee battery strap, with dimensions, or any info to help me build, or where to purchase this item? Norton part number is 21032 in the spares book.
All the best,
500T side stand
Will someone please let me know how the side stand spring is attached to the frame on a 500T. The parts supplement lists a spring loop pt. no. C186. A photo. would be ideal.
Thanks,
Rod
Intermeidate gear shaft
Does anyone know if the oil hole on the intermediate gear shaft (the one for the intermediate gear) should be at the top or the bottom when the shaft is re-inserted into the crankcase. I deglected to record its position when I removed it.
Jubilee timing marks
I assembled the timing gears on my 1965 Jubilee today but I need some reassurance!
I am restoring an engine dismantled by someone else so I have no reference for how the timing gears should align.
Mainshaft lengths
What is the length of the gearbox mainshaft as applied to a 1953 Model 7, swing arm version? I'm doing up a 'box for a friend who lives some distance away and it would be nice to get it right first time around.Thanks, George.
