About to re new the valve guides in the R4 Cyl Head I have. Have I read that these heads are prone to cracking around the inlet guide area when removing or installing guides.
looking into my gearbox without any cogs i focused in on the cam plate when i rotate it its buckled about 2mm, ish. would it straighten up or is it a case of just renewing it .
Barry
just wondering, is les still on the site haven't seen any messages lately.
Barry
i built up a 1956-Norton, moted it [altough it doesn't need one] did a Norton- Owners -Club- Factory-Record .. tried Dvla but no record of last-reg..[ the bike is a 1956-Dommie -99- Scottish- bike,, so not an import..] DVLA.
I have recently purchased a 57 88 for restoration here in California and I've been trying to discover the original colour. The frame is black with the optional chrome mudguards - No sign of polychromatic grey.
Does anyone have any knowledge/experience of the Oberon replacement clutch slave?
Will the club have a stand and if so will they want members to display bikes or only Commando's?.
I'm still having issues with spark plugs failing since the engine rebuild which I can't seem to resolve.
Good evening everybody
I would like to ask if anybody knows which model/type of magneto a 1956 ES2 is supplied with.
I have attached a blurry image of the one on my machine.
Well done to the Rally Team for a splendid rally in Somerset, sorry I had to leave early.
The seat on my 74 Roadster is quite cramped when riding two up with my wife. Does anyone make an extended replacement which will provide more space and comfort?
Thanks Martyn
Hi - bought a 850 JPN last year from a guy that owned it since 1981 - looks to be the real deal but is there any way of verifying this?
On 1959 Model 50 which adhesive is recommended for fixing new rubber knee pads to chrome tank side panels ?
Mike Haworth
Has anyone heard of possible changes to the dreaded MOT from May 2018?
Hi everyone wanna check the clearanceson my commando's vernier iso's
measured it between the plastic disk thing on the side nearest to me (timing side) and it was at about 0.005 thou at the top and 0.004 thou at the bottom
Please, i need a little advice on my main bearing assembly (500T).
Next year the plan is to make vehicles registered before 1978 MOT exempt. Win
Has anybody ever glued the pads back on that come loose on a clutch plate. and if it can be done what would one use. tight arse lol
I'm in the process of a complete rebuild of a 1972 commando roadster combat. It is now close to finished but I can't seem to find any information on fitting a chain slider to the swing arm on the primary side.
Hi all. My fairly uninteresting questions go on unabated! I am told that the Roadholder forks fitted to my 1968 Atlas are not standard as they have the bellows type rubber gaiters fitted.
Can any kind person please advise me on the correct colour of the Norton decals on the petrol tank and the decals on the side panels on a blue 1973 850 mk1 Commando? Should they be silver?? Also what colour should the pinstripe on the tank be?
Hello all,
I have a friend restoring a 1970 "S" Commando & is in need of a rear mudguard. It seems to be unique in that it has a dent for tire pump clearance. The part number is 06.1402.
'74 850
Hi ,
I'm considering purchasing a pair of IKON shocks,could anyone recommend the model number . There are a few Ikon types available but which one pair to go for?
Hi All, I have been sent the following email and I thought this would be the best place to post it. Please contact Ada directly. I have no more details than you see below. Regards, Tony
Can anyone shed any light on exactly what problem this device is intended to address (cooling oil, obviously, but what in what context? I assume racing, but it would be good to know).
I ordered a pre-feather bed side stand for an ES2 last Friday and lo and behold! It arrived today.Well done guys! Really impressive turn round. George
I am about to refit the chromium plated side panels back on the petrol tank. I have purchased new black extrusion to fit round the edges of each panel - can anyone recommend a suitable adhesive ?
Mike Haworth
