NOC Shop
Hi. I'm a recent member and haven't been able to access the shop since i joined, all i get is a picture of a bike and nothing else?
I know this has been discussed a few times before but what tyres do members recommend for a 1976 Mk3 Commando that I have from new. I am trying to cure head shake/wobble and I appreciate that this can be a common problem with Commandos.
What's the best way to check/set the ignition timing on a '61 99?
I've done about 800 miles on my Navigator, runs well enough except for one thing, tick over speed is too high.
It ticks over at around 1800 rpm, far to high.
Hi, I've never used a torque wrench when tightening the heads on the 99s or Commandos I've owned. Question is, will a torque wrench fit into the back of cyl space for the rear nut and the two front recessed nuts?
Does anyone know the number of teeth on the fibre and drive pinions on a 6V Lucas DC generator Type E3H on a Model 7 (and 77) ? regards, howard
Evening. Hope someone can help as absolutely stuck. I am fitting the above to a Lucas SR1 magneto as coil is suspect.
Got the crank and new rods together at last and dry fitted in crankcases. I turned down an old Superblend and roller bearing to make assembly easier and now need to know about sorting the end float.
hi all i have just purchased a quite nice 71 (although not registered till 73 ) commando , my intention was to replicate a 750 norvil i had back in the 80,s ( cafe racer etc you get the idea ) :-) .
Hello
My 1962 650ss with a 99 barrel finally started the other day but sadly needed a bike starter to get her running.
I have recently acquired a Norton Model 50 1959 wideline. On taking the petrol tank of to get access to the carburettor I noticed a crease in the right side top tubing similar to the one on the attached photo.
I'm looking for Ian's contact details if anyone can help.......
aye up all me again :-) just noticed that on the front end of my commando ie wheel rim disc ( floater ) etc there are stars stamped on them ?
hello ,
on my 55,19s i am thinking of fitting a 6 volt battery without the plastic box. i already have one of the plastic boxs you put a battery in. but the lid doesn,t seem to secure. it makes for a loose fitting battery.
I have a 1950 Big 4 with no spark. I have checked the usual. plug, cap, lead and have got to the pickup on the Mag. I am trying to remove it but its more than fiddly. Very difficult to get at the 2 screws holding it on.
Hello all, new member here and with also a 'new' bike, recently registered with the DVLA on an age related plate dating back to 1951. extremely happy with the bike but needs recommissioning, its a Norton 500T 1951.
Not sure whether this should be in the Electrical forum, but here goes.
Folks,
I want to change the rear mudguard on my Dommie.
A friend of mine has a spare mudguard from model 88 to give me.
Checking the spare parts list they have different part number.
I recently replaced the layshaft bearing in the gearbox and at the same time replaced various bushes and also the kick-start return spring.
I need to replace a leaking top gasket on my 2017, 961 sport, the first two questions I have are, where can I obtain a gasket and secondly, once I have taken the tank off the bike can the rocker gasket be replaced with the engine in.
Can the guy that emailed me about the B3T advert contact me again? Your phone number's not working.
I ordered various parts on the 27/08 and they arrived 30/08. This is a very big thank you to the volunteers that keep our fine machines fettled.
What's the best way of checking that the pressure plate comes off the plates squarely?
Roadholder dropped on the mat this morning. It says the rally is in March 2025.
Is there an oil seal on the drive side main bearing, 1959 ES2.?
Is it available?
I've followed the setting procedure in the manual - "Screw-in till touching the pushrod then back-off half a turn" but still get fearsome noises from the box when going into gear or changing gear. What's the solution to the problem?
My 1962 650SS expired on the run back from the MGP last week and I am now resigned to undertaking a complete rebuild in an attempt to create a reliable oil-tight unit with something resembling the original power output (i.e.
Hi All
I had a bit of a disaster while filling my oil tank when oil dripped down onto the rectifier and there was aloud pop and a puff of smoke. Turns out these are no longer available so I have bought a Podtronics unit from AN.
