Question to the Webmaster
Chris. Some time back, someone complained, here on this message board, that there was not a way that a mistake made with ones message entry could not be self edited or corrected.
Norton owners searching for original 650 pistons need to be aware that a set now on eBay.com (which also come up on eBay.co.uk):
Item number: 330590049009
Hello all, I realize this is probably the wrong location for this, but I am an American at the Empire rallly and have met several wonderful members from the UK & various other countries as well!
Hi can anybody help? I am trying to put the cyl head onto my Mk.11a Commando but upon lowering the head to the barrel, the gap of the valve clearance is about ? of an inch even with the adjusters all the way down.
Hi to all you other happy 961 owners.
I wonder in any of you have found and feel able to recommend a rear paddock stand for my cafe racer ?
Dear All,
I don't remember whether I've already asked this question (sorry if so):
My 99 is now running very well whith her new Pazon ignition.
Thankyou so far to members who have kindly replied to my previous messages.
Hello What if anything are the NOC doing for the Queen's birthday in 2012 ?
The 7 inch front brake fitted on many Norton models up to around 1954 has always been found to be lacking power. I have started on the renovation of my one and discovered some possible reasons why it is so!
Here's a thread on the AccessNorton site well worth a look if you're not aware of this forthcoming mod: http://www.accessnorton.com/commando-starter-upgrade-t10150.html
Need some verification re the position of the throttle/slide valve position when viewed through manifold.
Thanks to feedback from my query regarding the Norvil/Comeau starter motor, I'm going to fit one to my Mk3 (no starter at the moment.)
Hi all,
I'm having diffeculty removing the front isolastic to give it a clean up and check the adjustment - this the first time I've tried to do this!
It look like this wonderful software is up to it's tricks again.
What Kev was probably trying to say was that he will be heading to Applecross for the Tay Valley branch bash.
He will be leaving from Norfolk.
...when you adjust a primary chain or toothed belt, at what point in the rotation of the engine do you make the adjustment? The chain/belt tightens and slackens depending on where the crank is sitting.
Nortonians, I can't get rid of an oil leak from the chain case following my recent re-build. The output shaft from the gearbox looks central in the primary case oil seal which has been renewed.
Friend has a 499cc 30M Manx, Eng No.11M97287, Built 8/5/1961, Frame No.11M97287 built ?/4/1961.
Can any one recommend a repairer for an alloy tank as I have had a minor mishap and dropped my Norton whilst loading onto a trailer resulting in a dent in the tank. Thanks, John
It has always struck me that it's a shame to throw away a perfectly good Commando brake drum when the sprocket is worn out. Being cast iron it would be difficult to weld a new sprocket to the drum after machining the worn teeth off.
Hi have a domi 99 1961 it is fitted with a wassel 12 volt alternator and has bridge rectifier fitted but no zener diode or any other method of voltage control is this correct?
Hello, all. I've just joined up, sadly as merely an interested party and not as a Norton owner right now.My name is Tom Parker and I'm writing you from Portland, Oregon in the United States.
Some of you might find this tip useful, especially if your eyesight is not as good as it used to be.
Hi there all. Could someone let me know please where I can get the "kickstart axle cork washer"....Part number A2/355.
I am about to remove the forks on my bike so I can do away with the gaiters that are on there at present..it is my intention to fit the chrome plated exterior coil springs underneath the bottom yoke....my question is..can I leave the existing inte
I have a 76 Commando 850, all I have done is take off the battery and fit a new one, upon switching on the ignition - absolutely nothing, on turning the switch to the lights on position then the red and green warning lights come on but nothing els
Hi all,
This unusual P11 powered Norton sidecar racer was probably constructed and raced in the UK in the late `60's or early `70's?
