6v to 12v conversion
What's involved and is it worth it?
<!-- /* Font Definitions */@font-face{font-family:"Times New Roman";panose-1:0 2 2 6 3 5 4 5 2 3;mso-font-charset:0;mso-generic-font-family:auto;mso-font-pitch:variable;mso-font-signature:50331648 0 0 0 1 0;} /* Style Definitions */p.MsoNormal, li.MsoNormal, div.MsoNormal{mso-style-parent:"";margin:0cm;margin-bottom:.0001pt;mso-pagination:widow-orphan;font-size:12.0pt;font-family:"Times New Roman";mso-ansi-language:EN-AU;}table.MsoNormalTable{mso-style-parent:"";font-size:10.0pt;font-family:"Times New Roman";}@page Section1{size:595.0pt 842.0pt;margin:72.0pt 90.0pt 72.0pt 90.0pt;mso-header-margin:36.0pt;mso-footer-margin:36.0pt;mso-paper-source:0;}div.Section1{page:Section1;}-->
Iâm running my WD16H at 12V, 40W dynamo with standardarmature.
Whats involved â 12V regulator, battery and bulbs. Most ofthe electronic regulators give you the option of wiring for either 12V or 6V.You can also change the armature to a 12V one but I havenât bothered. They havetwice the number of windings, so a finer wire which is supposedly more fragile.
Is it worth it? â opinions vary. How often and far do youride at night? I did it because I canât resist changing things.
Pluses - 12V is more tolerant of the odd poor connection, morereliably bright (ha ha) lights.
Minuses - the revs at which the dynamo produces enoughcharge to balance the draw rises, unless you have changed armature. So extendedaround town night riding could possibly drain your battery.
I have fitted LED pilot and tail/brake lights, which drawalmost nothing so the ammeter shows positive even at very slow speeds fordaytime lights on riding. And at 30MPH with 35W headlamp on I get a positiveammeter reading.
Iâm running my WD16H at 12V, 40W dynamo with standard armature.
Whats involved â 12V regulator, battery and bulbs. Most of the electronic regulators give you the option of wiring for either 12V or 6V. You can also change the armature to a 12V one but I havenât bothered. They have twice the number of windings, so a finer wire which is supposedly more fragile.
Is it worth it? â opinions vary. How often and far do you ride at night? I did it because I canât resist changing things.
Pluses - 12V is more tolerant of the odd poor connection, more reliably bright (ha ha) lights.
Minuses - the revs at which the dynamo produces enough charge to balance the draw rises, unless you have changed armature. So extended around town night riding could possibly drain your battery.
I have fitted LED pilot and tail/brake lights, which draw almost nothing so the ammeter shows positive even at very slow speeds for daytime lights on riding. And at 30MPH with 35W headlamp on I get a positive ammeter reading.
Thanks Iain for your very helpful response. Since I don't ride at night I'm not sure it 's going to be worth the effort.
