All Forum Posts
Ethanol
my fastback tank has now started to melt! another victim of ethanol fuel i have always used super unleaded what a waste of time that was,has anyone used anything with succsess that will seal a glass fibre tank? regads nick
sprocket
Could someone please give me the distance from the inside of the swingarm axel plate to the cetre of the drive sprocket so i can set up a special hub in a commando swingarm regards nick
Gearbox question
I recently had an issue on my '57 Dominator model 77 gearbox, it would shift fine 1st-4th gears, but when down shifting from 4th-3rd, or 3rd-2nd, most of the time the lever moved, but no gearchange.
1962 650SS exhaust
Text to go with my post, the attachment went when i posted but the text disappeared !
I am having trouble identifying the exhausts fitted to a 1962 650SS. They are not the standard items usually seen, which are handed LH and RH.
Arc welding question
This may seem a bit of a cheek, because its not on my Commando but has anybody ever done any welding on their bike, if so what bits must you isolate from getting spiked? I was thinking battery and boyer box?
A handy gadget
i've just sent off for a digital voltmeter that plugs into a cigarette lighter socket from ebay for about £2.50 inc p&p I know most bikes don't have cigarette lighters but I sent off for one of those too.
389/689 on a 650SS?
Hey everyone finally done a bit more work on my Norton.
Just got the single carb conversion off of her and was thinking I've got one minty fresh 389 and was wondering fitting the matching opposed float bowl 689 if I can find one.
Tank decals
I have just resprayed the 71 black and am about to lacquer. I was about to apply the decals to the black base coat prior to this stage.
Back wheel
Can someone give me the position (centre)of the back wheel rim from the inside of the swing arm axel plates?or should it sit in the centre of the swingarm? this is for a special wheel in a stock swingarm regards Nick
Manxman
Recently on ebay a Norton was advertised for sale, it was blue it was advertised as being possibly a Manxman . Did anyone see it, was it one
