All Forum Posts
Manxman
Hi
I need advice on the brand and size,to replace my front and rear tyers on my 1961 Manxman.
Thanks Geoff
4S camshaft
my 750 commando is stripped down at the moment it has a ported big valve head and a standard camshaft at the moment but i have in my spares a good 4s cam with a vernier sprocket that i am thinking about fitting,or should i stick with the std one??
Model 7 speedo
Hi, can anyone tell me the correct speedo for a 1954 model 7 please?
What else would work with a 2-1 drive and 19 inch wheel,anything 1600??
Many thanks Keith
Flywheel cracks
Latest issue of one of the classic bike mags has a part article about restoring a Model 18. The article concludes with a picture of a crack in one flywheel casting - with a remark that this is a common defect.
New website suggestion
One think that may be useful on a new website is email notification of forum replies. Just a thought.
Apart from the posting errors the only things I have found slightly frustrating are:-
Swinging arm lubrication
I know the Commando swinging arm should be lubricated using 140 grade oil but I recently learnt of an owner using grease; used because oil would leak out. Has anyone got any tips on this topic please?
Chris
Carb floats perished!
I have only done 3000 miles on my Commando since a complete rebuild, on pressing the tickler on the RH carb to flood the float bowl prior to starting, petrol immediately started pouring out of the tickler.
Head rebuild
I'm in the process of rebuilding my 750 head and replacing the thackery washers with solid spacers, problem is I can find no definitivemeasurement for the end float between rocker and spacer.
KLG HS3 plug
Does anyone know the reach of this 18mm spark plug, its temperature and what equivalents might exist from other manufacturers?
100 years of the curly N
Next year will be 100 years of the Curly N That was Designed by a female , yes this was Ethel Norton she also test rode her father machines , so it there going to be a party and a Norton get to gather
650SS
Hi All,
I have a Dominator 650ss, it has had a lot of work done to it and is beautiful to look at and is in the cafe racer guise but has retained the original 650ss engine and frame which match.
Roadholder enquiries
1st question. On Atlas damper units and on some Commando dampers there are four holes to allow the oil to flow through. On later Commando dampers there are only two holes and slightly higher up(on the tapered portion).
Oil tank fixing rubbers
Hi All, I have just completed the assembly of Rubik's oil tank on my 71. On the final tweaks, checking the tightness of the oil feed banjo, I managed, without too much effort, to shear the new(off the noc shop)top rear mounting rubber.
Sprocket size???
Hello all. The rebuild of my 75 registered mk2A roadster (a showroom leftover) is allmost at the point of refitting the primary drive and i notice the gearbox final drive sprocket has 20 teeth which i beleave should be 21.
Soda blasting
I have been digging around on t'internet and there is a good lot of gen about "DIY soda blasting." I recently bought a little compressor from Lidl so thought I would give it a go.
Dommi 99 Wideline tank
I am replacing the GRP "Manx" style tank on my 1959 Dommi with a secondhand Norton steel tank but it has no obvious fixings. It seems I'll have to use the strap system from the big Manx one, but surely that is not right? Any advice?
Knee pads
Hi All, Try again for the 3rd time, This website is C**p, without doubt the worst I've used .
Back to the subject. I have a 1960 ES2 with the chrome panels on the petrol tank and I'm trying to find a pair of self adhesive Knee pads
