Hi all,
Went for a ride this evening and had to turn my lights on at dusk - the charging light came on (as it usualy does) - the bike missed a few times and cut out. It started OK and got me home. I also noticed that the indicators stopped flashing, while using the head light.
I don't think I'm getting enough from the alternator to run the bike, the headlight and indicators - all together.
I've read a few threads about the Sparx 210 watt alternator - would this be a good upgrade and fix the issues?
The bike is a '72 Roadster, it has a belt drive conversion and I use a halogen bulb up front and LED rear light.
If a sparx alternator is the answer - what's a good supplier in the UK (not obvious from Goggle!).
Thanks for any help - Paul.
I am assuming you have a s…
As Paul implies - if the a…
As Paul implies - if the alternator wiring is not damaged it is not likely to be at fault. It contains nothing more than wiring, and 120 watts should be sufficient. That leaves regulator or poor wiring, or a poor connection somewhere - or the battery isn't holding enough charge to tide you over at low revs (tick over with indicators on). The magnetic rotor is conceivably at fault but thats not likely either.
If the rotor in the altern…
If the rotor in the alternator is the original - 40 years old - loss of magnetism is a likely cause of your woes. If you could substitute a known good rotor that would be a good way to check if this is the case.
I agree with everyone here…
I agree with everyone here. It's most likely to be a fault - usually wiring but possibly the Zener. Last suspect would be the alternator so it could be money wasted unless you check the wiring system first.
I am assuming you have a single phase 120w alternator fitted - which should be up to the job. Is the problem the alternator? Could the rectifier/zener diode or control box (whichever is fitted) be at fault. In my experience, the rectifier is the most likely suspect. I have no experience of the Sparx 210W alternator. I assume it would be 3 phase - so you would need the appropriate control box to go with it. With all the spare amperage, you could run all sorts of accessories - heated grips being a favourite at this time of year. I would give the beer cooler a miss though... Gordon.
