Oil leaks - Navigator
Hi is it normal for oil to appear on top of the head nuts when eng is running. I am having a lot of problems trying to stop oil leaks on the right head and have oil coming out between fins and running down barrel.
what yorks will fit a wideline featherbed frame will any of the commandos fit can any one help please
I am rescuscitating a 1936 Model 18 which hasn't run for a few years. It had a tidy up in the early eighties, but this didn't include the engine or gearbox which I doubt has ever been out up to this point and are substantially worn.
I want to replace the rusty old studs and nuts for cosmetic reasons, but they are only available in stainless AFAIK.
Since I wasa boyI have admired the Commando and last November I finally picked up a 1971 LR fastback...rough but running nicely. In March I did a mini rebuild and after a little problem with the pinch bolt fork leg got it MOT'd last weekend.
Hi I have a 72 Commando Interstate which is fitted with an after market seat which is amazingly hard. Because of the foot peg position coupled with a hard flat seat i find myself becoming the pillion each and every time i pull away.
I have recently bought a 72 Commando 750 and just become a member here.
I recently delivered my 961SE to Norton to fix a minor indicator gremlin (loose earth pin), service, MoT, embody available updates and to fit those lovely short pipes.
I have an old 71 roadster just trying to get it up and runing, it has developed a big leak from the rear side of the primary chaincase.
Hi all, I'm trying to take out the central damping rod from my 1939 16H.
Would anyone have for sale, or know of, a good vertical shaft top bevel gear, with no wear on the shaft surface (where it runs in the bronze bush).
Hi all, Can someone tell me if you can get a gearbox sprocket for a 19H, 20 or 21 tooth please, I know they are 19 tooth originally, thanks,Tony.
Check here for some great pics by Paul Coene:
http://www.flickr.com/photos/29850993@N02/sets/72157634120163338/
Just been on a couple branch sites, fine, but I can't find a way back to the main site????? The 'Back' button doesn't work. 'Home' leaves you at the Home for the Branch page, is this right???
Al Osborn.
I was going to post a thread about Cree LED lights as used by the mountain bike guys. They seem very powerful and available quite cheaply on ebay
I have looked in the Classified Section and I can not see anything which tells me how to place an advert.
Obviously I am missing something as I have previously used the Classified Section or has the format changed.
I received the following message in error I think. It came to me as I am the Secretary of the Northern California Norton Owners Club. Anyway here it is:
Hi Mike
First off, I know this is an impossible question to get right.
I am just looking for suggestions, of which I hope there will be many.
my original barrel has a cylinder liner.
The outer diameter about the liner (steel)is as great (09/64 inch material thickness), that
between thesecond and third fin only 01/16 inch original cylinder stock available
can some one tell me, which bearing is better for the drive side? (crankshaft)
RMC22L (roller bearing)
UMC22 ( double row bearing) or
MC22 ( ball bearing)
thanks
When did Nortonuse the Twin Leading shoe Brakewith InternalLinkage, andhow long before it was put on the outside?
We have only been back for 24hrs and are missing France already !
Does anyone have any tricks for fitting a centre stand spring?
Hi. a new boy so please give me some slack. Just got myself a 72 750 Commando and have sorted most of the initial issues but I have the infamous leak from the tacho drive.
The spare parts list shows part no. E2/492, a washer T1 , Front chain case, inner portion crankcase washer.I have assembled the chain case and drive without the washer!
My clutch has been dragging badly when when its been running for aver 10 miles or so.
